Neutral light not working
Posted: Wed Jun 12, 2013 11:02 pm
by Dumbjer
I am currently resurrecting my 1990 600. The neutral light is not coming on when in neutral. I have not checked the bulb, but if the bulb is fine, what is the next step in diagnosing the problem?
Thanks in advance!
Re: Neutral light not working
Posted: Wed Jun 12, 2013 11:19 pm
Check the neutral switch on the left side down at the bottom, behind the sprocket cover. The wire is held on by a screw; it could be loose, covered in chain filth, eaten by squirrels ...
Posted: Sun Jun 16, 2013 10:20 pm
by Dumbjer
Thank you !
No squirrels found. Just a bunch of chain lube residue, grit, and crap.
Cleaned out and light works.
