Rear Signal Bulbs
Rear Signal Bulbs
After a stretch of bumpy terrible roads the real signals don't light up anymore. The front signals now double up in speed so I suspect a short somewhere. When I look at all the wiring everything looks fine though. I'm guessing maybe the bulbs just fried ... both sides? What type of bulbs are they so I can see if replacing them helps. Thanks.
'88 FZR400
Re: Rear Signal Bulbs
The bulbs are 1157 (edit - wrong, should be 1156). Check for security of the sockets; loose sockets will shake and pound the bulbs.
- Kevadlilleke
If one of the signal bulbs is out, the relay will speed up to indicate the fault, this is normal. Have you checked whether the bulbs are ok?
2012
2013
2014
2012
Sorry - the rear SIGNAL bulbs are 1156. My brain saw "rear signal" but read "tail light".
Thanks, Don. Will pick some up at Wallmart today.
BTW, you live in the GTA? Notice your profile says Scarberia ... I also live in Scarberia, by the bluffs
'88 FZR400
Not too far from Warden station.
