I have a 95fzr600r that needs to be inspected and when I bought it she didn't have any turn signals on her. The wires are there, but there were no signal lights. I bought some led turn signals and wired them in. I didn't wire the running light (blue wire) in the front. I dont want the marker lights on all the time.Now here lies my problem...
No matter wich way I try to signal all 4 marker lights flash.. I signal to turn left and my left marker lights flash but so do the right ones. Same goes for the right side. Is this because I didn't wire in the front running light wire? I'm pretty sure I don't have the wires backwards.... Please help!!!
Turn signal help!
Re: Turn signal help!
The signal indicator on the dash is a cross-over point for the left and right circuits. With the normal signal bulbs, the teeny little dash lamp doesn't flow enough juice to turn on the other circuit; with LEDs, it obviously does. Pop out the dash bulb.
Thanks Don. I'll give it a try!
