help with 08 R6 VR
help with 08 R6 VR
I just got my 08 r6 VR in the mail and it has a sixth pin instead of five. I just need help on how to wire it up or info to whether the sixth pin even serves a pupose
Re: help with 08 R6 VR
07-08 wiring is the same
check through the manual for the wiring
http://www.r6messagenet.com/forums/r6-h ... anual.html
Upgrades:
The sitxth pin is a dead pin from what i remember reading. You can follow the write up for the mod upgrade located here and either ground the 6th pin or not use it.
I left the top middle terminal alone.
'92 FZR600
Lots of Powder
Lots of Powder
If you look in the WIKI you will find that this already coveredcoopfzr wrote:I just got my 08 r6 VR in the mail and it has a sixth pin instead of five. I just need help on how to wire it up or info to whether the sixth pin even serves a pupose
