I'm looking to do the same to the Fiz.
Here is what I am thinkin:
Get a replacement solo cowl and mount two braces across it, wide enough to clear the rear fairing. Then mount two sheets of aluminum/fiberglass to those, with an extra support brace running underneath the tail section, just in front of the license plate, adding rigidity to the two sheets. You would then drill and attach the saddle bag mounting fixtures to the sheets, and the bags to those.
The best (ideal) part of it all would be that it would all be able to be removed by just unlocking the rear cowl and pulling it off, replacing it with the original cowl.
Here are two very quick mock-ups I did:
You could either run the top braces over the cowl, or run two shafts through two holes drilled into it.
What I am looking for from you inventive types, and you know who are, is any advice.
For the two sheets, I'm thinking 1/8" aluminum would be plenty light/strong.
As for the braces? Maybe extruded aluminum H or X would be plenty rigid, and easily mounted on top of the cowl, or just a half inch al tube going through the cowl.
Any help?
