N,nortstudio wrote:Well, somehow I messed up the top coat. I was following the directions I had printed out - and did the final VERY fine wet sanding with a lot of soap on the SprayMax clear coat. It ended up leaving spots of dull, cloudy white in some areas. Just when it looked like I was done. UGH!!!!
case of more haste less speed i am afraid. cloudy patches on clear coat is usually moisture related . Here in the tropics you need lots of water filters on your spay gun air line. Too early in the morning or just before sunset will have the humidity too high for a decent clear coat.
I would hazard the guess that the soap was not completely washed off and allowed to air dry. Luckily you were painting a bike not a boat had a whole clear coat job "de-laminate" off a hull first trip out to sea Y-Geo was non too pleased! Lots of
![I swear! :swear](./images/smilies/swear.gif)
![Whistling :whistle](./images/smilies/whistling.gif)
