![Image](http://pic100.picturetrail.com/VOL569/2630066/5242086/326064118.jpg)
![Image](http://pic100.picturetrail.com/VOL569/2630066/5242086/326064285.jpg)
![Image](http://pic100.picturetrail.com/VOL569/2630066/5242086/326064382.jpg)
![Image](http://pic100.picturetrail.com/VOL569/2630066/5242086/326064496.jpg)
![Image](http://pic100.picturetrail.com/VOL569/2630066/5242086/326064571.jpg)
![Image](http://pic100.picturetrail.com/VOL569/2630066/5242086/326064720.jpg)
and replacement foot pegs.
![Image](http://pic100.picturetrail.com/VOL569/2630066/5242086/327835317.jpg)
MK,modkingfzr600 wrote:fuel cells are always able to be made to order, so if you need one just let me know. .
people do it if they race and/or are using a different tank cover that cant fit over stock tank which is pretty much any tank cover thats not fzr.yamaha_george wrote:MK,modkingfzr600 wrote:fuel cells are always able to be made to order, so if you need one just let me know. .
Your fuel cells hold more fuel OR just to suit a particular airbox set up with "tank shroud" ?
modkingfzr600 wrote:george, this particular fuel cell holds a little over a gallon "less" than stock. this along with the tank being lighter saves weight ,also it provides a little lower center of gravity and it has an internal baffle which eliminates sloshing of the fuel.....and it allows you to use the spin-on fuel caps.
MK,modkingfzr600 wrote:I hear ya don , the internal baffle in this fuel cell pretty much cancels out all sloshing , and you are correct about the aluminum tanks breaking in a car-bike crash. I purchased 2 bricks of fuel cell foam for the fuel cell that i built for china racer , i purchased it on ebay and it was a good quality foam although it doesn't feel much like foam. The foam fibers look like enormous rubber scotch brite fibers.
