Alright well shredex told me to come to you because you make custom fairings for people.
I need a custom made R6 or R1 Rear Fairing With a backseat cut on it.
I dont know what i need for a undertail do i need a custom one? Or can i use A fender eliminator?
Let me know asap!
ModKing I need you.
Re: ModKing I need you.
your making this alot harder than it has to be just get an r6 tail you can try a bunch of different ways be in the end its gonna take abit of effort to change the tail. i would say use a r6 sub frame would be your easist route cause you only have to peice in the four points the other ways you have to do a bit of fabricating to use a passenger seat making supports. or just use a single seat like the airtech tail mine is on by just 2 bolts in the rear pretty easy
XxxYoOoOxxX
Yes i am doing the airtech tail..But i want to know if modking could make me a custom one with the undertail and have the rear fairing so i could put a back seat on it
- shredex
mdking can make you a custom undertail for the airtech tail. he cant make you a whole airtech tail though.
you buy a airtech tail, then send it to him to make a undertail for.
Sorry if I made it seem he makes the tail.
he could probably do it though...modking has many skillz...
haro504 wrote:your making this alot harder than it has to be just get an r6 tail you can try a bunch of different ways be in the end its gonna take abit of effort to change the tail. i would say use a r6 sub frame would be your easist route cause you only have to peice in the four points the other ways you have to do a bit of fabricating to use a passenger seat making supports. or just use a single seat like the airtech tail mine is on by just 2 bolts in the rear pretty easy
XxxYoOoOxxX
O yea..I guess i didnt read what u said to me clearly
i took a peice of 1/8 steel and bent it to the inside shape of the tail and bolted it to the sub frame so i could ride someone on it if i wanted to but it sqashed the rear shock
modkingfzr600
