YZF 600 Gear Ratios
1st 37/13 (2.846)
2nd 37/19 (1.947)
3rd 34/22 (1.545)
4th 28/21 (1.333)
5th 25/21 (1.190)
6th 29/27 (1.074)
Primary Reduction Ratio 82/48 (1.708)
Secondary Reduction Ratio 47/15 (3.133)
figured I would cross post this over here so we had it...and it can get into the wiki eventually.....
Engine
Bore x Stroke 62 mm x 49.6mm
Carburetion 36 mm Keihin CV Downdraft Carburetors (4)
Compression Ratio 12:1
Final Drive O-ring chain
Ignition Digital TCI
Transmission 6-speed w/multi-plate clutch
Type 599 cc, liquid-cooled, 16-valve, DOHC, inline four-cylinder
Output 90 bhp (67 kW)
Brakes/Front
94-96 Twin 300mm drilled discs 4 Piston Sumimoto Calipers
97-07 Dual 298 mm floating discs w/4-piston calipers
Suspension/Front
94-96 Machined 2 section conventional forks adj for preload rebound and damping
97-07 41 mm telescopic fork w/adj. preload, compression and rebound damping; 5.1" travel
YZF 600 Specs
YZF 600 Specs
SOLD
SOLD
- ShogunTX
- Level 4.5
Re: YZF 600 Specs
I don't have much in the YZF realm in the wiki, I know those guys have their own forum......Let me know where you were going to throw this in the mix and I can add it. My YZF is currently down with a busted fairing, uneven railroad tracks popped the rear braket off??
