here is what i did
![Image](http://i39.tinypic.com/24zw2tf.jpg)
i counter sunk a piece of alum angle bracket, then threaded the foot of the lift, dropped a hardened allen head into that sucker to hold it, then ran a hardened bolt thought that, spun the head of the bolt on the grinder to make it go away, used fender washers to sandwich it to the old spool holders, ran the both through the angle bracket and capped it with another nut... solid as ever and works perfect! best part is, to use on a spool style all i have to do is remove the nut
this is what it looks like (please forgive the extra tape on the lift, i did not want it to scratch if it did not work so i wrapped it all up tight, 2 days now on it and it works great!!!
ill get some pics after i paint it or powder it up
![Image](http://i39.tinypic.com/1zy7var.jpg)
![Image](http://i42.tinypic.com/96hvgx.jpg)
![Image](http://i44.tinypic.com/nbad1s.jpg)
![Image](http://i44.tinypic.com/aekysl.jpg)
