Dogbone how-to and info
Locked
haunter
Post by haunter »
Second Post. Please add to the wiki!
Re: stock dogbone length?
Post by thatkid »
haunter wrote:anyone know........I need to raise the tail on the 600.......
To raise the tail about 1.5"-2" I go with a 5" center on center. Stock length is 5.8" center on center. 1mm shorter bones will yield about 2.4mm raise on average.
I've always made mine out of 6061 T6 because it's inexpensive and strong enough.
If your buddy can get it, go with 7075 T6. It's about 3 times as much but has almost double the strength rating. 2024 has about a 7k lb higher rating than 6061 but isn't as easy to come by and doesn't weld very well. Not that there will be welding of dogbones but....
Make them .25" thick and then standard dimensions after that.
The below figures should give people an idea of the strength ratings of aircraft grade aluminum. Keep in mind any of these aluminums need to be a T6 for strength. A 6061 0 will not be anywhere near as strong as a 6061 T6. All data can be found at http://www.matweb.com
2024 T6 -
Shear Strength - 41,000psi
Fatigue Strength - 18,000psi
Machinability - 70%
Yield Tensile Strength - 50,000psi
6061 T6 -
Shear Strength - 30,000psi
Fatigue Strength - 14,000psi
Machinability - 50%
Yield Tensile Strength - 40,000psi
7075 T6 -
Shear Strength - 48,000psi
Fatigue Strength - 23,000psi
Machinability - 70%
Yield Tensile Strength - 73,000psi
haunter
Post by haunter »
Hope that helps.
that does help.
I am going to get some dogs for both bikes......and my buddy should be able to make em at his machine shop easy enough
any suggestions on material? a certain type of AL?
Post by thatkid »
Hope that helps.
that does help.
I've always made mine out of 6061 T6 because it's inexpensive and strong enough. If your buddy can get it, go with 7075 T6. It's about 3 times as much but has almost double the strength rating. 2024 has about a 7k lb higher rating than 6061 but isn't as easy to come by and doesn't weld very well. Not that there will be welding of dogbones but....
As I said though, the ones I've got on my bike now I made from 6061 and they have given me no problems to speak of. If I'd had 7075 I would have used it just for the overkill factor but I have to order that if I want it. A local shop carries 6061 for $3/lb. Your buddy can probably get 7075 without a problem so I would say go for it. Make them .25" thick and then standard dimensions after that.
haunter
Post by haunter »
thanks man. You mind if I edit this down some later and move it to the wiki forum so they can have a wiki dogbone article?
Post by thatkid »
haunter wrote:thanks man. You mind if I edit this down some later and move it to the wiki forum so they can have a wiki dogbone article?
Nope, go to town. I'll even help out a little more. The below figures should give people an idea of the strength ratings of aircraft grade aluminum. Keep in mind any of these aluminums need to be a T6 for strength. A 6061 0 will not be anywhere near as strong as a 6061 T6. All data can be found at http://www.matweb.com
2024 T6 -
Machinability - 70%
6061 T6 -
Machinability - 50%
7075 T6 -
Machinability - 70%
icontender
Re: Dogbone how-to and info
Post by icontender »
post can now be found on the wiki
HOW-TO: DOG BONES
icontender
[Edit] Corrected Link pointing to the WIKI Dog Bone article under Hybrid: Customization / Fabrication
Reason: edited duplicate content in the WIKI
ShogunTX
Level 4.5
Level 4.5
Post by ShogunTX »
This post already in the WIKI under Dog Bones
haunter
Post by haunter »
thanks to whoever did the reformat into the HOW TO, looks great!
/thread
Locked
Return to “WIKI - Discussion, Submissions, Corrections...”
