Page 1 of 2
Everything You Need To Know About Carburetors
Posted: Tue Aug 05, 2008 3:00 am
by ShogunTX
We strive to provide the most up to date and informative material for the FZR community. If you have any questions, comments, or suggestions related to the content you've just read in the WIKI feel free to post it here.
Wiki: Everything you need to know about carburetors
Re: Everything You Need To Know About Carburetors
Posted: Tue Aug 05, 2008 9:14 am
by PIMPMYFZR
kool , because as soon as im done with the yzf swingarm the carbs are my next adventure !!!
Posted: Tue Aug 05, 2008 9:18 am
by ragedigital
I need to work on this when I get the chance. Lord knows I've been through my carbs 30 times this past year.
Posted: Tue Aug 05, 2008 1:51 pm
by fadlan12
We should also post carb settings for reference.
Idle adjust
Posted: Sun Sep 21, 2008 8:29 am
by ALMOST
Hey fellow fzrers. Have not posted in a while. Quick question about the idle adjust screw/knob. Which way to turn and how sensitive are the turns. My idle has slowly gotten worst. I used the adjust knob but I think I made it worse.
Do we have any links to a proper carb cleaning with what should be checked or replaced. If not any useful information form anyone here and I will do a write up with photos/video. Things like dipping them, needle replacement, gaskets, floats, those brass color tube things that lose there oval orifice shape.
Re: Idle adjust
Posted: Sun Sep 21, 2008 8:32 am
ALMOST wrote:Hey fellow fzrers. Have not posted in a while. Quick question about the idle adjust screw/knob. Which way to turn and how sensitive are the turns. My idle has slowly gotten worst. I used the adjust knob but I think I made it worse.
There is already a well documented sticky on carb cleaning on the forum. If you think that a new picture would help or you feel something is lacking please feel free to add to it in the WIKI.
-->WIKI<--
Re: Idle adjust
Posted: Sun Sep 21, 2008 8:37 am
by ALMOST
OK thanks yamahageorge, any thing about the idle adjust.
Re: Idle adjust
Posted: Sun Sep 21, 2008 9:23 am
ALMOST wrote:OK thanks yamahageorge, any thing about the idle adjust.
A,
I can never remember which way either, so I let the bike warm up (short ride) then twiddle the knob till it sounds right ( at about 1200rpm usually)
HTH
Re: Idle adjust
Posted: Sun Sep 21, 2008 9:25 am
by megaloxana
IIRC turn the knob clockwise to raise the idle.
Re: Idle adjust
Posted: Mon Sep 22, 2008 6:06 pm
by ALMOST
Thanks, it does not seem to have to much an effect.
Re: Idle adjust
Posted: Mon Sep 22, 2008 6:18 pm
ALMOST wrote:Thanks, it does not seem to have to much an effect.
a,
That is odd, check your air box seating & filter cleanliness plus the fact while you have the air box off that the idle cable is actually working when you twiddle it may just be frayed broken.
Re: Idle adjust
Posted: Mon Sep 22, 2008 6:27 pm
by haunter
megaloxana wrote:IIRC turn the knob clockwise to raise the idle.
correct
Re: Idle adjust
Posted: Mon Sep 22, 2008 6:31 pm
by ragedigital
Yes, clockwise will increase the RPMs. Yours might be stripped or unscrewed al the way, perhaps?
In this photo, you can clearly see the idle adjust screw - top left. It has the flex area covered in the black plastic sheathing.
*Note: These are Cali carbs and have 2 tubes shown on the right that may or may not be like your bike. I removed and plugged those holes.
Posted: Mon Sep 22, 2008 9:41 pm
by ALMOST
Thanks for the great pic. Yours look really clean. Did you dip them and do a rebuild?
Posted: Mon Sep 22, 2008 10:42 pm
by ragedigital
No dip... just carb cleaner. A brass brush on some things. I was lucky to get a bike in such good condition.
The only items I updated were emulsion tubes from Factory Pro and a DynoJet jet kit.
