Everything You Need To Know About Carburetors
- ShogunTX
- Level 4.5
We strive to provide the most up to date and informative material for the FZR community. If you have any questions, comments, or suggestions related to the content you've just read in the WIKI feel free to post it here.
Wiki: Everything you need to know about carburetors
Re: Everything You Need To Know About Carburetors
kool , because as soon as im done with the yzf swingarm the carbs are my next adventure !!!
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
I need to work on this when I get the chance. Lord knows I've been through my carbs 30 times this past year.
We should also post carb settings for reference.
Idle adjust
Hey fellow fzrers. Have not posted in a while. Quick question about the idle adjust screw/knob. Which way to turn and how sensitive are the turns. My idle has slowly gotten worst. I used the adjust knob but I think I made it worse.
Do we have any links to a proper carb cleaning with what should be checked or replaced. If not any useful information form anyone here and I will do a write up with photos/video. Things like dipping them, needle replacement, gaskets, floats, those brass color tube things that lose there oval orifice shape.
FZR 600 91 D&D
Re: Idle adjust
ALMOST wrote:Hey fellow fzrers. Have not posted in a while. Quick question about the idle adjust screw/knob. Which way to turn and how sensitive are the turns. My idle has slowly gotten worst. I used the adjust knob but I think I made it worse.
There is already a well documented sticky on carb cleaning on the forum. If you think that a new picture would help or you feel something is lacking please feel free to add to it in the WIKI.
-->WIKI<--
Re: Idle adjust
A,ALMOST wrote:OK thanks yamahageorge, any thing about the idle adjust.
I can never remember which way either, so I let the bike warm up (short ride) then twiddle the knob till it sounds right ( at about 1200rpm usually)
HTH
- megaloxana
Re: Idle adjust
IIRC turn the knob clockwise to raise the idle.
Re: Idle adjust
a,ALMOST wrote:Thanks, it does not seem to have to much an effect.
That is odd, check your air box seating & filter cleanliness plus the fact while you have the air box off that the idle cable is actually working when you twiddle it may just be frayed broken.
Re: Idle adjust
correctmegaloxana wrote:IIRC turn the knob clockwise to raise the idle.
SOLD
SOLD
Re: Idle adjust
Yes, clockwise will increase the RPMs. Yours might be stripped or unscrewed al the way, perhaps?
In this photo, you can clearly see the idle adjust screw - top left. It has the flex area covered in the black plastic sheathing.
*Note: These are Cali carbs and have 2 tubes shown on the right that may or may not be like your bike. I removed and plugged those holes.
Thanks for the great pic. Yours look really clean. Did you dip them and do a rebuild?
FZR 600 91 D&D
No dip... just carb cleaner. A brass brush on some things. I was lucky to get a bike in such good condition.
The only items I updated were emulsion tubes from Factory Pro and a DynoJet jet kit.
