Bleeding a dry brake system in 5 minutes!
match417
Level 8.0
Level 8.0
Post by match417 »
We strive to provide the most up to date and informative material for the FZR community. If you have any questions, comments, or suggestions related to the content you've just read in the WIKI feel free to post it here.
95FZR600
Re: Bleeding a dry brake system in 5 minutes!
Post by 95FZR600 »
Very good write up. :thumbsup:
Even easier for a dry system is the Mighty Vac system. Literally 5 minutes also.
M in KC
Level 2.0
Level 2.0
Post by M in KC »
Yep reverse bleeding is the bee's knees. Phoenix makes a kit but yours is no doubt is more fiscally responsible. Everyone just be careful when doing this as the hose connected at the bleeder can come off under pressure and soak painted parts and yourself with brake fluid which will ruin your day. Thanks for sharing. :cheers:
95FZR600
Post by 95FZR600 »
M in KC wrote:Yep reverse bleeding is the bee's knees. Phoenix makes a kit but yours is no doubt is more fiscally responsible. Everyone just be careful when doing this as the hose connected at the bleeder can come off under pressure and soak painted parts and yourself with brake fluid which will ruin your day. Thanks for sharing. :cheers:
Your exactly right. You have a little time to clean if it does spew though. If it sits you can forget it.
match417
Level 8.0
Level 8.0
Post by match417 »
M in KC wrote:Everyone just be careful when doing this as the hose connected at the bleeder can come off under pressure and soak painted parts and yourself with brake fluid which will ruin your day.
Exactly the reason why I had a hose nearby to spray down stuff. The little vacuum hose isn't under much pressure if you do it slow.
Fartblood
Level 4.5
Level 4.5
Post by Fartblood »
I just paid my stepdaughter a fiver to keep pumping the lever, let her wear herself out instead!
megaloxana
Post by megaloxana »
Fartblood wrote:I just paid my stepdaughter a fiver to keep pumping the lever, let her wear herself out instead!
haha nice
'92 FZR 600
Luke-a-Tron
Level 2.0
Level 2.0
Post by Luke-a-Tron »
You should go back and bleed it again after like a week. There will be small air bubbles in the nooks and crannies of the caliper. Since the bleed nipple is always the highest point on the caliper, the air eventually finds it way up there.
I used the mighty vac when I replaced my lines and master cylinder. What a fantastic tool to have.
billy_awesome
Level 2.0
Level 2.0
Post by billy_awesome »
Very good write up, lots of people don't know how to bleed properly. It's not as intimidating as people think it is.
megaloxana
Yeah my buddy has one of those vacuum bleed pump containers...Very useful and super easy.
'92 FZR 600
Return to “WIKI - Discussion, Submissions, Corrections...”
