Streetfighter Turned Racebike
Dyyryath
Post by Dyyryath »
Finished getting the motor back together and put the newly painted bodywork on her for the racetrack. I took these an hour or two ago while I was waiting to go out on the track.
reelrazor
Wrench
Wrench
Re: Streetfighter Turned Racebike
Post by reelrazor »
VERY g******amn nice.
dru86
Level 1.5
Level 1.5
Post by dru86 »
that bike is hottt
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
Looks very nice!
dru86 wrote:that bike is hottt
He'll certainly find out. My bike is black and gets very hot at the track. With the sun beating down and the heat from the bike, buying a black bike was a poor choice on my part.
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
hubba hubba!
Upgrades:
sweekster
Post by sweekster »
:ihi:
