Page 1 of 3
07 08 r1 tail swap
Posted: Tue Feb 01, 2011 1:12 pm
by rustyabiding
Im starting my tail swap and I have the complete plastics from a 08 r1, and a yzf 600 tank. Im ordering a tail light, seats, and a undertail soon. I was wondering if anyone else has done this swap for these years? I did a search and havent found anything, from what i found was around years prior to 06. Does anyone have any pics or know anyone who has done the swap for this year? Thanks!
Re: 07 08 r1 tail swap
Posted: Tue Feb 01, 2011 6:47 pm
by haro504
go to the last pages
viewtopic.php?f=30&t=4209
Posted: Tue Feb 01, 2011 11:23 pm
by rustyabiding
Thanks that really gives me insperation to do mine! Is it worth buying the subframe or do you think i could do my own mounts? Also with a subframe bolted to the original frame is it strong enough to hold two people?
Posted: Wed Feb 02, 2011 7:37 am
rustyabiding wrote:Thanks that really gives me insperation to do mine! Is it worth buying the subframe or do you think i could do my own mounts? Also with a subframe bolted to the original frame is it strong enough to hold two people?
Some later models have bolts holding the sub frame to the frame so it should be ok just make sure when you do it that everything is a nice tight fit and the bolts are high tensile steel going thro a tube NOT sheet metal so the load is spread.
Posted: Wed Feb 02, 2011 2:44 pm
by haro504
remgio made his own mounts for a 400
viewtopic.php?f=7&t=4799&start=60
i would have probally made my lower mount differently if i had a welder but im confident in my final result
Posted: Thu Feb 03, 2011 10:11 am
by rustyabiding
Thanks for all the info! I think im going with getting a subframe since it looks like it has bolts that hold it to the rest of the frame (thanks yamaha george). And haro your bike looks amazing with that tail, makes me cant wait to do mine.
Posted: Sat Feb 05, 2011 9:17 am
by haro504
mrfreeze used a r1 tail and subframe if you look through his posts you can see his version
Posted: Sat Feb 19, 2011 2:22 pm
by rustyabiding
So I got my subframe now, along with an undertail, front seat, and pod filters. How do I decide on where to cut the old subframe and where to drill holes for the new one? Also does anyone have any measurements?
Thanks!
Posted: Sun Feb 20, 2011 2:39 pm
by haro504
heres some pics of what mrfreeze5 did with an r1 tail bout the best i can do he has a write up on it but you have to search for the info you need viewtopic.php?f=30&t=4400&start=105
Posted: Sun Feb 20, 2011 2:45 pm
by haro504
your gonna want to mount the tank first and match the tail with the seat on it to the tank. i have an extra front tank bracket i made a few up when i made mine ill ship you one for 15.00 ImageImageImageImage
Posted: Sun Feb 20, 2011 6:02 pm
by rustyabiding
I got the subframe on now but all i have is some crappy cell phone pics. Ill get some better ones once i can get ahold of my girlfriends camera. but here they are
Posted: Sun Feb 20, 2011 6:11 pm
by rustyabiding
haro i might have to take you up on those mounts at somepoint
Posted: Sun Feb 20, 2011 6:47 pm
by haro504
im sure ill have one if you need it
Posted: Tue Feb 22, 2011 2:40 pm
by mrfreeze5
Nice progress there, it looks really good. One thing I notice on yours is a small gap between the top of the frame horn and the subframe. I had this same issue and had to weld about 1" of material on top to extend it up a bit into the subframe. I havent seen the 07+ subframe closely, but I know on my 06 subframe, once those horns were extended and shaped properly into the subframe, they actually became somewhat structural since they butt up against the underside and help support weight. I have every confidence in the setup to hold a passenger. But, you may want to beef up that front mount a little, it looks a bit small to me.
I also like your tank mount. Its nice and simple and looks like it will do the trick.
Posted: Wed Feb 23, 2011 9:00 pm
by rustyabiding
Thanks!
I thought about that too, i have to wait a while until i can get to a welder though. But in the meantime i have alot of other things left to do on it! I was thinking about switching to a r1 front fairing because I have all the plastics, but I kinda grown partial to the big round eyes of the fzr, so ill probably just sell all those plastics
