YZF600R barrels, pistons, use with FZR head, and bottom end
Posted: Mon Nov 22, 2010 11:29 pm
by STN
Can you use a yzf600r's barrels, and pistons and conrods, and use the fzr head and bottom end?
Re: YZF600R barrels, pistons, use with FZR head, and bottom end
Posted: Tue Nov 23, 2010 1:48 pm
by cad600
You want the YZF600 head. You also need some other parts, but it creates a 661cc engine (commonly called the 660).
Posted: Sun Nov 28, 2010 1:14 am
by STN
Yeah, but aren't the heads almost the same? They use the same bolt pattern, and the valves are roughly the same size, and the cams are the exact same. Has anyone ever attempted to just use the barrels, conrods, and pistons?
Posted: Sun Nov 28, 2010 8:41 am
by cad600
The YZF600 head has slightly better flow characteristics. Will the FZR head bolt on - yes. But the YZF600 head will better optimize the setup.
Posted: Sat Dec 04, 2010 3:22 am
by STN
Ah, that it would, but by how much? If I use the YZF head then I'll need the yzf carbs, which shamefacedly are the only bits for the 660 I dont have. How much of a difference would it make if I stuck to stock head and fzr carbs. I'm going for cheap horsepower. Although I could get the carbs for 50 bucks...
Posted: Sat Dec 04, 2010 11:50 am
by cad600
32mm Mikuni carbs for the FZR600 vs. 36mm Keihin carbs for the YZF600. To me, the Keihin carbs are easier to work on but that is a personal preference.
Posted: Sat Jan 15, 2011 5:02 pm
by Cursed94FZR600
does anyone know if the YZF had 32mm carbs at one point and later in production they changed over to 36mm? if they did, do you know when they made the change?
Posted: Sun Jan 16, 2011 10:04 am
by cad600
PM'ed you back on this.
