so i thought about it for a while, pulled the air box apart, put just the bottom half on the carbs and laid the tank in place, there was contact sh#t. ok it needs cutting, so off i set. here's pics but unfortunately i did have to use tape
first i placed a rule over the bottom half, so i wasn't cutting through the breather nor the drain then marked it up.
slide the 2 halves together to mark up for cutting
here's the result, 1.5cm shorter
close ups of the breather and drain
the top on (wonky btw) nearly ready to mark up then cut
look there's the WHITE TAPE
if there's any contact i want to know exactly where, as little cutting as possible, so i put gasket sealer on the underside of the tank to show the contact area
more TAPE
tank fits no contact, just 2 smallish holes to TAPE over
air intake cut
just needs welding up, Tomorrow weather permitting, the fumes don't do your lung's any good so needs to be done outdoors, hopefully there'll be no performance related issues, fingers crossed
