Since there isnt a stand alone write up on this, just the info hidden in the suspension sticky, here's my write-up for the swap based of what I did and learned during my swap. This should be a good resource for future conversions. Hopefully this can help take some of the guess work out of the process for those who are not sure if they can handle an upgrade like this. Ill also touch on related upgrades and swaps as they pertain to this conversion, but will not necessarily go into depth in the interest of specificity.
EDIT: Ok, somehow I missed the write up that ABS already did, but I still think this should be a valuable resource, It f'n better be, I spent a while on this thing...
Swapping a 96-07YZF600r Swingarm onto a 1989-1999 FZR600r and Options for Monoshock Upgrade
*Should also apply to FZR400 models
The Swingarms. Mine's bigger than yours
There are 2 different types of swingarms on FZR600s and there are lots of reasons to get rid of it. The 1989 and 1990 Years used a basic boxed steel swingarm. It is weak and ugly. For a bike with lots of power added or a wheelie happy stunter this can be very bad news. This swingarm weighs in at approx 11lbs(I may be wrong, I dont trust my scale anymore, but I will use my measurements for at least relative comparison)In 1991 Yamaha replaced the swingarm with the deltabox swingarm which weighs in at about 16lbs. It is stronger with more material and bracing and is more visually appealing, and the length from end to end is just slightly shorter than the 90 swingarm. The length difference between the deltabox FZR swingarm and the YZF600 swingarm is minimal and should not produce a very noticeable change in handling as a result except to maybe a very experienced rider as the wheelbase change is almost negligble. It also weighs in the same as the deltabox FZR swingarm at 16lbs bare.
The other major difference between the FZR and YZF swingarm is the pivot tube. The FZR is 8.75" between the frame rails. The YZF pivot tube is about 3/4" wider than that FZR, so it will not fit into the frame as is. You will need to cut down both ends of the pivot tube so that it will fit into the FZR frame, about 3/8" per side. I used a hose clamp as a template to make my mark around the tube and used a dremel to cut it off at close to the right size and then "fine tuned" the size with the grinder, just make sure both sides are equal. If youve got some energy and some time to kill, a hacksaw will work just fine. Once the pivot tube has been cut, the dust caps will not seat fully onto the tube. They will hit the weld on the swingarm. On mine, the interference was fairly obvious and I was avoiding grind the welds for clearance, so I lighlty touched the edge of the cap to the bench grinder and made a slight notch(maybe 1/8") and coupled with light grinding of the weld made for a nice fit. The distance from end to end on the YZF swingarm pivot bushing should be 8.470". This will allow the swingarm pivot bushing to fit inside the frame with seals and washers included installed on the pivot tube. You could probably use the FZR pivot bushing and not have to cut it since the pivot bolts are the same size, but I did not have one at the time of theis project.This is made from hardened steel and will not be easy to cut. I would recommend a band saw if available, dont use a grinder, they can be so imprecise and then you need a new bushing. The cut need to be perpendicular to avoid premature wear on the seals and bearings.
The pivot bearings inside the pivot tube are a press fit needle bearing that goes into the the outer portion of the tube that is bored out slightly lager that the rest of the ID of the tube, so that when they are pressed in they sit flush with the outer edge of the swingarm and wont press in farther. You will need to take a small grinding wheel on a dremel or air grinder and deepen this bore enough so that the bearings will sit flush. Be forewarned removing the existing pivot bearings can be very difficult and is nearly impossible to remove intact and reuseable, so have 2 new bearings ready for this swap. I took a small strip of 1/8" thick x1/4" steel plate. Cut it to the exact length and rounded the edges so that it sat on the edges of the bearing. This allowed me to use a solid punch in the center of the steel bar to force the bearings out. It still took some work though. By cutting off about 1/4" of each end of the pivot tube, the bearings no longer sit flush. To ensure you dont ruin your new bearings, you can take an old bearing that is still in good shape and go at it on a bench grinder for a bit to reduce the OD of the bearing so that you can slip it in and out to check the bore depth and not have to whack it back out. It may take a while, the bearing is made from hardened steel, which I hear is pretty tough stuff. In case you havent noticed yet, this entire conversion could be done in a day or weekend if you take your time using nothing but hand tools, torque wrench, dremel, hacksaw(optional if youre precise with a dremel. Youve got to be precise though!!), a drill and tap, and a little loctite. Im sure a case of beer wouldnt hurt either.
In addition to being stronger and slightly larger than the FZR's the YZF swingarm is wider, allowing for a wider wheel (5", which will not swap into the narrower FZR swingarm without major machine work) which brings us to the primary reason for doing this swap.
89-90 FZR600 Swingarm
91-99 FZR600 Swingarm
YZF600 Swingarm
Side-by-side comparison. The angle is a little off on this one, the YZF swinger and FZR swinger are very close in length, this pic makes it look much longer. The 89-90 swinger is the longest of the 3 by maybe 1/4".
And here's a comparison of the width differences between the YZF and FZR swingers
A little trick to getting the bearings out without trashing them is to make a driver. I dont have a blind bearing puller, so I went this route. This piece stays in my toolbox for the next time I need it. Drop it in the pivot tube and seat it against the backside of the bearing. Then use a piece of tube or a long drift to drive it out. I also keep the one bearing that I shaved down to be a slip fit. It comes in handy if you do this swap more than once. Ive done it twice and am about to do it for a third, so yeah, its handy for me.
The Wheel. Its all about the wheel.
The FZR600 comes stock with a 18" diameter wheel. 1989 models have a 3.5" wide wheel that fits a 140 tire, 90+ models have a 4" wheel that comfortably fits a 150 section tire. The problem is that there is a limited tire selection for 18" wheels in the FZR requires. So by swapping to a YZF swingarm, we can maintain close to stock wheelbase, while converting to a 17" YZF wheel with a 5" width that will fit a 160 section tire nicely. Many riders have used larger section width tires on these rims with varying results depending on brand and size, but that is another topic altogether and I wont discuss at this point. 160/60/17 is the stock tire size for the YZF wheel. One advantage of switching from the 18" rear wheel is that it lowers the rear end somewhat depending on what size tire you began with before the swap. This works out well for me since I have kinda short legs and I can flat foot the bike now comfortably, but then again, my bike had a taller rear tire than it should have to begin with, so it was pretty drastic for me, but most riders can expect about a 1/2"-3/4" drop. This can be addressed for taller riders with different dog bones to dial in their ride height.
150/60/18=25.09" OD
160/60/17=24.56" OD
The YZF wheel is a perfect match for the FZR wheel
The YZF forks and front wheel can be used very easily on the FZR if you want to upgrade from a 3" wide to 3.5" wide front wheel to run a 120 tire. But, thats another topic again.
The Brakes. Youve gotta stop some time
According to online microfiche, the part numbers for the calipers are the same for FZR600s and YZFs. The rotors have different part numbers, but they are the same diameter and thickness, and share the same mounting holes. The only difference is the cross drilling of the rotor. So you could conceiveably use a FZR caliper and rotor on the YZF wheel to save $$. I am still running my stock FZR caliper with the YZF swingarm with no issues.
Rotor Comparison: FZR on the left, YZF on the right
Here are a few pics of the assembled swingarm with a FZR caliper mounted:
(BTW, if dogs had thumbs, this swap would have been much easier...)
At this point in time, I decided to add spool mounts to the swingarm. Some steel rod, a basic lathe, a M6 tap, and basic welding skills made this a simple and worthy add.
Sprockets and Chains. What makes it go?
Stock gearing on a YZF600 is 47t in the rear. No need to upgrade to a different tooth count sprocket as most quick accelration sprocket kits for the FZR upgrade from the stock 45t rear sprocket to 47t and in some cases drop from 15t to 14t on the front sprocket for an even greater acceleration increase at the sacrifice of top speed. A 520 conversion is needed to make everything work without machining the sprocket hub. The YZF sprocket is offset about 8mm outside of the front sprocket. This wont do. It will destroy a chin with a quickness if it even moves. By offsetting the chain in the rear, you must match the location on the front sprocket. This can be done one of three ways.
The most involved and expensive is a YZF600 engine swap. It is mostly bolt in and will align the sprockets perfectly. The second is to machine the sprocket hub down to the appropriate width. I am not fond on this solution sinceit requires custom maching at great expense and time when there is an easier solution available. The solution I used was using a Vortex 520 front 14t sprocket for a Kawasaki ZX6rr with the stock FZR600 engine. The splines match perfectly to the FZR transmission utput shaft and offset the chain out 8mm. Perfect fit with no custom machine shop work. The only problem with this route is that you cannot keep the stock lock washer to keep the sprocket nut from loosening due to the offset of the sprocket. I drilled the transmission output shaft and tapped it for a bolt so that I could tighten it down with a washer underneath and loctite it in. I also used loctite on the sprocket nut, which is usually a good idea anyway. Use blue loctite, not the red, or you'll never get it back off for that next sprocket and chain change out. Another small issue with this sprocket is that it has a raised boss where the nut tightens down. It is approx 1mm tall. I ground this smooth on an bench grinder to allow more thread engagement with the nut. Stripping that nut would be a very bad idea. I also painted it afterwards. It wont help much, but the sprocket is gold zinc plated and where I ground down was bare steel. Luckliy the nut covers most of that area, and what isnt covered shouldnt get worn off IMMEDIATELY, but hey, who's sprocket nut isnt rusty?
Vortex Kawasaki 636 520 sprocket next to FZR600 520 sprocket
Kawi sprocket installed. Note ill fitting sprocket nut. This was before grinding down the boss on the sprocket. The safetly washer still won't fit though.
I no longer have the packaging for my front sprocket, so I don't have the PN, but according to the Vortex website, the Kawi 636 only has 520 pitch available and the part number is 3288 and is available in 14-16t configuration for the 2003-2006 636. This shot shows the side that mates to the transmission, this is not the raised boss that I ground down to clear the nut, its on the other side of the sprocket. Sorry, don't have a pic.
Here is the JT sprocket. A great option. First, it does not have the raised boss that the vortex sprocket does, so it doesnt need to be ground down for nut engagement. Also, the two threaded holes allow for a way to secure the nut. You can use two bolts safety wired together around the sprocket nut to help keep it from turning. This has been used quite successfully. In fact, I will likely be swapping to this one myself for more peace of mind.
Shocks
The rest of this conversion depends heavily on what shock you are going to use. I wont go into great detail on the shock swaps, we can save that for another write-up. The stock FZR shock will work and bolt up but is well known for being lacking in the performance dept. I believe that the stock YZF shock is far too long for the FZR and there is nowhere to mount the reservoir, but Im not certain on this fact sicne I never bothered messing with the stock YZF shock.The easiest way to upgrade the shock with this swingarm swap would be to use an aftermarket FZR replacement such as a Ohlins, Penske, or Fox if you can get your hands on one. Another popular and relatively easy swap is the FZ1 shock using a FZR spring. These are going to be your easiest swaps if you can find them and should offer great performance if set up properly. Some other brave souls have tried or are trying(waiting for solid answers) various other shocks including Busa shocks, kawis, etc. If youre clever enough, you can make anything work I suppose. One other popular shock to swap on the FZR is the 06 R6 shock. While this shock is a huge improvement over the stocker and is fully adjustable, the spring rate is much lower, and should have the spring replaced to a heavier one. The average rider trying to do this swap on their back porch do not have the skills or the resources to use this shock effectively with the YZF swingarm. It can be done, but due to the larger overall size of the YZF swingarm the reservoir hits the crossbrace. The only way to remedy this is to rotate the shock 180* to have the reservoir facing forward. This requires cutting, welding, and some basic fabrication. If you're a decent welder(or know one), have some steel, and some time, you can fab a new mount. You can either start from scratch or retrofit. If you retrofit the existing mount and rebrace it, you'll need bushings for the upper mount bolt(R6 uses a 12mm bolt, FZR uses 10mm, FZR mount is wider than the R6) that take up the difference. These have been made by several board members and may still be available or can be made in batch relatively inexpensive at a machine shop. I have many pictures, part numbers and measurments for this shock and this swingarm to work together, but I will not include it here since it is unlikely that most builders will go quite so far on a near bolt on conversion, just one pic for reference. If you would like more information on this swap feel free to message me or check the write up at the FZRArchives. So, overall, you're fastest, easiest method of dampening your rear suspension would be a shock already designed for the FZR, but if you're brave enough, come up with something original and share with the rest of us. The dogbones to connect the shock to the swingarm will vary depending on the shock used and rider height and preference. These can either be bought in stock length, lowering links with multiple heights, you can make your own out of 1/4" steel plate, have them custom made, or try different bike's links for a good fit.
ABS made a great post with oem lengths of shocks for different bikes in the Archives' suspension sticky. So if you are feeling adventurous or find one for dirt cheap on ebay and want to try it, here's a reference to start with.
OEM Shock Lengths-Thanks ABS!!
EDIT: Since my swap was done in 2007, the newest shock out there was a 07. But another board member has successfully used a 2008 R6 shock on their bike, flipped 180* without modification to the shock mount. It looks like the reservoir is lower and does not have the slanted top that interfered with my 07 shock. So if youre doing a YZF swingarm swap and want to use a R6 shock, try the 08. Looks like it would bolt right on like any other R6 shock swap. you would just need the spacer bushings and shorter dogbones! Here are some pics(with FZR400 swingarm on 600 frame)
Pics courtest of Hagalout
Rearsets and Peg Mounts
The rearset clearance topic has come up lately and is an important topic. The stock peg mounts will not clear the wider swingarm as they are. Some trimming will be required to clear the swingarm or aftermarket rearsets can be used. Personally I am running the rearsets made by China_Racer 1 and could not be happier. BUT, I cannot take full advantage of their adjustability.Due to clearance issues, I can only use 2 or 3 of the lowest and farthest forward settings, luckily this is a comfortable position for me. I also had to slighlty shave the master cylinder stud to clear as well. Its damn close, but there's enough space I think. Some users have tried Woodcraft rearsets with good results, but I am not sure if they clear out of the box as I have not laid hands on them personally. Many riders have had good results from trimming/grinding the stock mounts to clear. There appears to be sufficient material to do so and this is a very inexpensive fix. Be cautious if you are grinding them down though. The mounts are aluminum and aluminum can do a number on a bench grinder wheel by clogging it and making the process more difficult and less precise. A bandsaw/hacksaw/linear cutting device may be more effective depending on how you are set up.
More than likely, the bracket that holds the brake light switch will interfere with the new swingarm. This bracket needs to be cut off. To maintain use of the rear brake light is a simple fix now that the brake switch is gone. A hydraulic brake switch that replaces the banjo bolt at the master cylinder. It uses a simple 2 wire hookup and is less than $20 from the local dealership or online store. The banjo bolt thread pitch is 10mmx1.25. I used K&S PN 12-0010 and picked it up locally. I cut the stock plug off the old switch and soldered it on to the new switch, but standard bullet connectors from radio shack work too if you dont mind cutting the stock harness.
courtesy of:abs600fzrr
Here is pic of the right rearset before trimming the MC stud. It did not hit at its normal location, but as the lever was pressed, it would contact during its travel. This may not be an issue with the stock setup. You can also get an idea of the dogbone difference with my setup. Since I used the R6 shock(about 10mm shorter) and I am a shorter rider(5'8") I had to make a drastic change in length. These are not the final dogbones I used, only what I used for measurement and mock up.
In this pic is a FZR lowering dogbone ranging from stock size to a 1.5" drop and my template is even shorter. This can vary depending on rider height, weight, and shock choice, but it gives you an idea.
That covers everything I can think of at the moment regarding the YZF swingarm conversion. It is relatively simple with basic knowledge and the right tools. I would rate this swap as a 2.5 difficulty out of 5, 5 being engine overhaul, and 1 being oil change. I was able to finish this swap in about 8 hours total and that was trying to puzzle things out as I went. If I did it again, Im sure it would go much faster. I would strongly recommend while you are replacing your entire rear suspension to replace all your bearings and seals at the same time. Wheel bearings, pivot bearings, linkage bearings, wheel bearing seals, pivot bearing seals, etc. You already have the parts disassembled and you dont know what was done to that vehicle before it was parted out. Its peace of mind that you wont have to tear into your rear end again in a few weeks or months to start repairs already.
And finally, a finished shot with the YZF swingarm install. Looks like stock, like it was meant to be there.
And an exploded view of the whole assembly
1000 Mile Evaluation:
I LOVE it. The bike is so stable at all speeds, it feels 10x better than a stock FZR. I was concerned the lower spring rate on the R6 shock was going to be a problem. I know I knocked some weight off my bike, but Im not sure how much, so it probably helped a little. By using the longer FZR rear suspension knuckle on the YZF swingarm, the extra leverage seems to help and the shock feels perfect to me, and I weigh in over 200lbs with gear. In fact, the shock was perfect with the preload all the way down. So I am not going to bother respringing this shock for this setup. If I do this swingarm swap again on a FZR, which is very likely, I will use the later model R6 shock flipped like mine and save the trouble of remaking the shock mount. Another thing I need to address with this setup is the sprockets/chain. For no apparent reason, my chain seems to bind ever so slightly moving around the front sprocket. The chain also rides pretty strongly on the chain guide with the way the ride height is set. I am currently running 14/47 gearing and love it, but I am going to switch to 15/50 over the winter to hopefully take some stress of the front sprocket, and help clear the swingarm a little better and maybe reduce a little friction and wear. I am going to switch to the JT sprocket and do the safety wired locking bolts. I am just relying on loctite right now and it doesn’t give me the warm and fuzzies. Id also like to get a steel rear sprocket too. Otherwise, the swingarm has been great and the bike rides like a dream. I REALLY like the 160 tire on there and personally have no desire to step up to a 180 on the FZR. Ive thrown this thing around in the canyons a few times and have been very pleased with how nimble and responsive it is while still feeling extremely stable. Its very confidence inspiring. I am sure the R1 forks help this fact out too, but the combination is fantastic. And even though the YZF swingarm is slightly longer than the FZR, I still have a shorter wheelbase than a bone stock FZR.
