well im doing a complete fairing swap from a 2002 r6
today i started on my 2006 yzf600 tank swap all is going well so far the tank is just siting on top of the bike till i can make some brackets and do some cutting tomorrow
im going to update this thread as new parts go on
my to do list
02 r6 fairings
06 yzf tank
powder coat rims black
things im still undecided on
r6 gauges
r6 swing arm
r6 forks
r6 controls
r6 rearsets
All Stock
Waiting For YZF Tank
Tank Set in Place
you're off to a great start, keep up the good work!
1996 FZR 600
K&N Pods
Barnett Clutch
Factory Pro shift kit
TurboDave wrote:so i found some more room for the airbox by moveing the velocity stacks 1 more notch into the box
here u can see the room it freed up
when i do final assembly ill go back and seal up around the stack to make it air tight
When I was looking into this, it is aldo the front to back you have to deal with, and even with getting rid of my filler neck and trying it w/o velocity stacks still could not get it to fit. So I hope it works for you. I did the 1/2 YZF and 1/2 FZR aribox.
TurboDave wrote:ya i was going to cut the underside of the tank to fit the air box
how does ur bike run with the half fzr half yzf airbox? did u have to rejet it?
TD,
These mods have been done a lot of times as whole or in part ) and most of what you will ever need to know about GOTCHA's is in the Forum's archives, the WIKI & SEARCH believe me are your best friendson this topic.
TD,
to save you a little searching I also tried to link alot of the How-tos, and mods in my thread below
I would stear away from moding your tank, since there is ton of alot easier ways to get the job done w/o tank modification.
ya the how too's and wiki on this site has been great for information after doing some searching im going with pods but i do not want to rejet my carbs so im going to flow my stock airbox and restrict the pods to the same cfm as the stock airbox that way A/F will be the same i will post more pics when the pods come in im also looking for 99 to 02 r6 seats if anyone has them
TurboDave wrote:ya the how too's and wiki on this site has been great for information after doing some searching im going with pods but i do not want to rejet my carbs so im going to flow my stock airbox and restrict the pods to the same cfm as the stock airbox that way A/F will be the same i will post more pics when the pods come in im also looking for 99 to 02 r6 seats if anyone has them
