Picked it up last night, it's all there, had to drain the tank and refill it with fresh fuel but that got it to fire right up. Carbs probably need to be cleaned still, but it holds an idle at least.
Enough yapping, on with pictures
Hmm... rotors slightly rusted.
This will be the first thing I get rid of... the 18" rear
Other side. It's got some kind of aftermarket cover there, it's shiny but scratched and has some sort of japanese characters on it.
Rusted rotor, part 2.
Ugly stock black exhaust
You can see the red spring from the Fox TC in there
Barebones cockpit, but I like it.
Not the prettiest, but it's there. All the factory wiring is intact, too. I have a box full of LABELED pigtail harnesses saying what was pulled off. Somebody took their time with this bike, too bad it's been sitting for like 8 months.
Battery won't hold a charge and needs to be replaced, but it seems like a lot of stuff has been removed. I'll have to get more pics.
So for now, immediate plans are just to clean it up and get it running properly again. Front brakes need to be bled, new battery, and I'm not very confident in the pretty shagged looking tires either. I dunno if I should bother replacing them or just look for a swingarm setup and a front end swap. Suggestions?
