YZF Head on FZR Block, Will it Work?
tkclow
Level 5.5
Level 5.5
Post by tkclow »
I have a lead on a YZF600r motor with a bad tranny for $50.00. What is involed with taking the head from the YZF and using it on my FZR? Would I need the carbs also. Thanks for any input
92 FZR600
Dual Headlight Upper Swap
Clear Taillight w/LED Bulbs
More To Come
sweekster
Re: YZF Head on FZR Block, Will it Work?
Post by sweekster »
If i recall that would make a 660...might want to search for that. I know it's been mentioned a few times now.
shredex
Post by shredex »
that my friend is called a 660 conversion...you will need a programable cdi and a spacer plate for the head which you can get from dru for $80 or something like that. I believe you need the yzf harness as well...
yes you will need the carbs...
if you dont wanna go threw all the work then i can take it off your hands because im in need of new motor...lol welll...head gasket but i might also need new rings which are $270!
haunter
Post by haunter »
you need more than just the head for the 660.
the_finch
Level 8.5
Level 8.5
Post by the_finch »
haunter wrote:you need more than just the head for the 660.
Yep, a little more than just the head...
Like the pistons, cylinders, cooling tubes, carbs, etc.
As far as fitting the head, someone with a little more knowledge of the yzf motors will have to chime in as to whether the head will swap out or not. I know that even if you go with the YZF head, the intake ports are different, so you'll have to use at least the intake boots from the yzf and probably the carbs, which don't fit the airbox properly.
IMHO, it would be too big of a can of worms to use that head, but if you could get the motor, even with a bad tranny it's worth something to someone, and someone here (like myself :whistle ) would probably buy it off of you for more than enough to get a decent head.
I'd buy it and either sell it whole or part it, and then buy the head to get your bike back on the road. my2cents
1997 FZR600RJ
demon_knight69
Level 4.5
Level 4.5
Post by demon_knight69 »
didn't cad600 just finish a 660 not too long ago? or did he just swap the whole damn yzf engine? IDK didn't feel like looking through his entire build thread :whistle
Fluff
1996 FZR 600
K&N Pods
Barnett Clutch
Factory Pro shift kit
sweekster
Post by sweekster »
demon_knight69 wrote:didn't cad600 just finish a 660 not too long ago? or did he just swap the whole damn yzf engine? IDK didn't feel like looking through his entire build thread :whistle
Fluff
He just did the full swap
tkclow
Level 5.5
Level 5.5
Post by tkclow »
the_finch wrote:someone here (like myself ) would probably buy it off of you for more than enough to get a decent head.
hey finch, is there something you need on it? I don't have a problem picking it up if I know someone can use some stuff from it, I haven't seen it yet. The guy did mention to me he thinks the case has a crack near the stator cover but I don't know how bad. Just let me know
92 FZR600
More To Come
shredex
Post by shredex »
i need something off it...pistons/rods/cylinders/head/cooling tubes/valve...lol
cad600
Post by cad600 »
Fluff
Yep, I just swapped a whole YZF engine in. I'm going to start working on the 660 again soon.
tjay
Post by tjay »
The yzf head will fit the fzr cylinder.
Here is what I did to make it work on my 560 superbike motor:
FZR 600 cylinders 1mm over (cylinder block machined to accept yzf cylinder studs)
yzf coolant tubes
yzf carbs, intake boots, throttle assembly/cables
fzr600 airbox modded to accept yzf carbs
Out of the box...worth 5hp at peak.
ahbeyra
Post by ahbeyra »
Just throwing this out there, but i will sell the spacer/base gaskets, a set of yzf pistons, yzf rods, yzf cylinders, yzf head, yzf carbs... and i think thats all i had for it... for $350 + shipping... Like i said, just putting that on the table for people to nibble at :)
Freestyle72
Level 4.0
Level 4.0
Post by Freestyle72 »
Might be interested in gasket plus spacer. Depending on spacer and gasket thickness(I wanna run as thin as possible I think it's like 3mm + .25 or something). And of course how much you are asking.
ahbeyra
Post by ahbeyra »
PM being sent, so as not to hijack the thread :D
95FZR600
Post by 95FZR600 »
Cad600 put the whole 600 YZF into his FZR but he is buildiong the 660. He knows what you will need.
