original state in 2003
Modifications:
Done:
YZF 1000 (thunderace) mirrors
steel breaklines
smaller blinkers in the back
black rims
two round rearlights
BSM exhaust
Race upper with projector lights
YZF 750 fueltank
zxr400 seatunit
R1 brakes
GSXR750 rearsets
FZR400RR swingarm
R1 USD frontend
future:
I have a spare engine with a busted gearbox.
A Wiseco kit, megacycle cams, dyna coild and an initech CDI are on the shelf ready to install.
planned paint scheme:
http://www.ks-workshop.com/report/model ... zf750.html
http://www.ks-workshop.com/gallery/gall ... zf750.html
Can any-one help me find more pictures of the Kenny Roberts Yamaha Lucky strike team with riders: Wayne RAINEY(USA) and Kevin MAGEE(AUS)?
2005:
2006:
2007:
2008
FZR 400 RR sP swingarm swop:
Ok there are some options for swingarms. They are rare and hard to find in the states. You can get the Delta Box from the 1990 FZR400, the box section swing arm for the 88-89 FZR400. You can also get a FZR400r 3en braced swing arm like an R6. You can also fit a FZR400rr 3tj swing arm.
FZR400rr 3tj. Ultra trick, light, stiff, EXTRA wide (widest) - work involved - you will need to make a spacer for the swing arm pivot bolt. Easy for any machine shop. You will need the rear brakes too. Axel is larger in diameter too
The 600 and the 400 swingarm are 22 cm wide at the point where they go into the frame
swingarm bearing sizes:
-outer diameter: 37mm
-inner diameter: 24mm
-length: 30mm
(250 mm = 1 inch)
The 400rr chain is smaller than the 600. The 400 is 428 and the 600 is 530.
Renthal makes makes conversion kits for the 400 and the 600 to change to 520.
Youl'll need a 520 rearsprocket for the 400rr wheel and a 520 frontsprocket for the 600.
By converting the sprockets you don't need a off-set front sprocket to outline the chain.
The original tailrisers are too long because the 400 RR wheel is 1" smaller.
