r6 front end
Posted: Thu Sep 25, 2008 9:02 am
by PIMPMYFZR
i found a line on whole r6 front end , the guys is actually trying to part it .. its an 08 .. the brakes wont swap over on the fzr ..right?
what would it take to swap the whole front end .. just have the fzr stem pressed into the r6 tripples ? or is it much more complicated then that ?
im going to look at the setup this afternoon ... how do u know if the forks are shot or tweaked just from looking at them ?
Re: r6 front end
Posted: Thu Sep 25, 2008 9:09 am
by cad600
Is this an R6 or R6s? If it's the R6 (radial mount) then the brakes won't even come close to swapping. The R6s will as long as your not putting them on '89 forks.
Your looking to see if the forks are bent or have other major damage. Also look at the triple clamp to see if it's messed up.
The swap is relatively simple. It will require either the swap of the steering stem, welding some material to the stem so it will fit properly, or a custom lower triple clamp. Yamaha_George pointed out a different solution that might be a lot easier though.
Re: r6 front end
Posted: Thu Sep 25, 2008 9:16 am
by PIMPMYFZR
yea im not sure yet on r6-r6s havnt seen pics just goona take a look in person .. im just afraid that i wont know how to tell if the forks messed up internally or if they are warped being that most ppl that i see parting brand new bikes are because they crashed or dropped it .. so im kinda skeptic because i really dont know what to looks for
Re: r6 front end
Posted: Thu Sep 25, 2008 11:54 am
by shredex
are you planing to put on the r6 front fairing too?
I would like to do that
Re: r6 front end
Posted: Thu Sep 25, 2008 4:09 pm
by PIMPMYFZR
shredex wrote:are you planing to put on the r6 front fairing too?
i really would like r1 setup but i changed tail about 3-4 yrs ago if i put a new front i know i will want a newer tail and right now anything else i put into this bike i want to be mechanical type upgrades .. my bikes got 24 k miles im sure the valves will be due in the next yr or two if not allready <i wouldnt know untill it breaks down > ive prob spent over a grand easily ...cosmetically buying stuff for the bike , 4 yrs later i wish i would of put it in the engine and brakes and suspension
Re: r6 front end
Posted: Thu Sep 25, 2008 6:14 pm
by YAM93
did you have the valves checked yet ? if not, 24,000 is overdue.
Re: r6 front end
Posted: Fri Oct 10, 2008 8:04 am
by abs929cbrrr
every 20K boy...check um asap.
Re: r6 front end
Posted: Fri Oct 10, 2008 12:08 pm
by PIMPMYFZR
abs600fzrr wrote:every 20K boy...check um asap.
ill prob get to that over winter if i still have it around
