I Need some Wirng Help on My R6 Dash & Controls Mod..PLEASE
Genesis
Level 8.0
Level 8.0
Post by Genesis »
I have completed the wiring on the R6 controls those are ready to plug in. One thing I'm not sure of is the 2 sets of female plugs up at the control end on the left hand side, what do they go to? also What Have you guys done with the choke lever? Thanks
I have started the Dash wiring, I am only half way through it. I got some questions, see the below photo and spread sheet. can someone please give me a hand? Thanks
EDIT--> ShogunTX says : Check out thatkids write-up
My FZR6 Rebuild
Re: I Need some Wirng Help on My R6 Dash & Controls Mod..PLEASE
Post by thatkid »
the two on the upper left should be to the clutch switch. If it senses the clutch isn't pulled in when you try and start the bike it won't start. I think that's it at least. I never had the choke switch so I don't know. Hope that helps maybe. Also did you get the Pods? Wanted to make sure you were happy with them.
Genesis
Level 8.0
Level 8.0
Post by Genesis »
thatkid wrote:the two on the upper left should be to the clutch switch. If it senses the clutch isn't pulled in when you try and start the bike it won't start. I think that's it at least. I never had the choke switch so I don't know. Hope that helps maybe. Also did you get the Pods? Wanted to make sure you were happy with them.
Helps a bunch thanks, I was just worried the horn was hooked up differently on the r6 then FZR
Yes did get the pods, look great, but I might be going with a FZR400 airbox if it fits, so those might be back up for sale.
My FZR6 Rebuild
match417
Level 8.0
Level 8.0
Post by match417 »
i might be a bit late, but I just did a switch conversion on mine to the yzf600 switches. wiring details below...
left handlebar:
horn - pink and black
headlight - yellow, blue/black, and green, yellow and blue/black are high beam, blue/black and green are low beam. blue/black runs straight over to the right side h-bar start switch
turn - dark green, brown/white, dark brown, red/yellow, black (i'm bypassing the turn sig relay and running through a flasher and separate relay, so i don't know exactly what wires are what, i do know that of the 5 wires, two are for running lights for each turn sig, one goes to the relay, and the other two go to the turn signals.
clutch - blue/yellow and black/yellow
right handlebar:
start switch - blue/white and black are for the starter solenoid
start switch - red/yellow and blue/black shut the headlight and gauge lights off when you press the start switch to start the bike, i wired them together, the blue/black runs over to the headlight switch on the left side.
kill switch - red/white and red/white
brake switch - green/yellow and brown
hope this helps
match417 wrote:i might be a bit late, but I just did a switch conversion on mine to the yzf600 switches. wiring details below...
left handlebar:
right handlebar:
hope this helps
M417,
Please place these details in the WIKI as this is very good info for all to see.
Thank you
Genesis
Level 8.0
Level 8.0
Post by Genesis »
left handlebar:
right handlebar:
hope this helps
are the colors listed above on the r6 side?
My FZR6 Rebuild
match417
Level 8.0
Level 8.0
Post by match417 »
not that i know of, but i've worked on a few yamaha's with the same color schemes, i just don't know about the r6 because i haven't worked on one. i can send you the same thing that i typed above but it's for the yzf600, but that won't help you. let me know what year r6 and what color/stripe wires and i'll try to find out for you.
Genesis
Level 8.0
Level 8.0
Post by Genesis »
match417 wrote:not that i know of, but i've worked on a few yamaha's with the same color schemes, i just don't know about the r6 because i haven't worked on one. i can send you the same thing that i typed above but it's for the yzf600, but that won't help you. let me know what year r6 and what color/stripe wires and i'll try to find out for you.
99-02 should be the same but mine inparticular is a 01
Does anyone have a wiring schematic for a r6?
My FZR6 Rebuild
Post by thatkid »
I did the R6 controls. The write up is in the wiki.
Genesis
Level 8.0
Level 8.0
Post by Genesis »
thatkid wrote:I did the R6 controls. The write up is in the wiki.
AND a very good write it was, feel free to use any of my pictures to fill in missing ones.
On the R6 controls, I have that pretty much done, just wondering how the horn wiring works.
I NEED more help with the dash wiring....... anyone?
My FZR6 Rebuild
match417
Level 8.0
Level 8.0
Post by match417 »
i just uploaded the r6 service manual, i don't know how to save just one or two pages from it, so i just put the whole thing online, right click and save the link below, electrical index is on 333. i also have a wiring diagram of the front headlight harness, but it just shows a few things, i put the link there anyway but i doubt it will help. i'll only have them up for about a few days, so download them. I also have a yzf600 one if anyone wants me to put it up to download it, let me know.
http://bobblebob.com/bobblebob/99-02R6_ ... Manual.pdf
http://bobblebob.com/bobblebob/frontharness.jpg
95FZR600
Post by 95FZR600 »
When you say dash, you mean digital gauges? I also have the wiring diagram for this on the wiki.
Genesis
Level 8.0
Level 8.0
Post by Genesis »
match417 wrote:i just uploaded the r6 service manual, i don't know how to save just one or two pages from it, so i just put the whole thing online, right click and save the link below, electrical index is on 333. i also have a wiring diagram of the front headlight harness, but it just shows a few things, i put the link there anyway but i doubt it will help. i'll only have them up for about a few days, so download them. I also have a yzf600 one if anyone wants me to put it up to download it, let me know.
Cool thanks Match.
95FZR600 wrote:When you say dash, you mean digital gauges? I also have the wiring diagram for this on the wiki.
Yeah digital Guages, it is on wiki? hmmm...I did not see it there But I will double check...thanks
My FZR6 Rebuild
Genesis
Level 8.0
Level 8.0
Post by Genesis »
OK I have specific questions that ether I'm missing something on the FZR and R6 ditigital dash diagrams or I just happen to have a odditity.
On the FZR wiring Harness I have a
yellow/black........ not sure what this goes too.
black.........ground...... nothing to attach it too.
NO gray......????
On the FJR speed sensor.....these don't match the wiring diagram
white...... ground???
black/blue.....power???
blue/yellow.....output??
On the R6 digital guage pigtale
yellow/black....... no gray to connect too, so does it go straight too the the green on the tach converter
black/blue........temp sending unit or ground
blue/yellow.....speed power.... just wanted to make sure it...because of the FJR sensor.
Thanks in advance for the help
My FZR6 Rebuild
match417
Level 8.0
Level 8.0
Post by match417 »
so the yellow/black you're talking about is yellow with a black stripe? that is odd, i don't think i've seen any wires on my fzr that are yellow with a black stripe. The clutch switch has a black wire with a yellow stripe, maybe when they made you're bike the machine mixed the colors wrong for the wire and it was meant to be black with a yellow stripe. If i were you, i'd follow that wire into the plug where it plugs into the harness, and see what color the wire turns into on the other side of the plug, most of the time it is the same, but it changes on a few, for example, the stop switch changes from red/white to red/black when it plugs into the harness.
as far as the black wire, the gauge lights share the same ground as the speed sensor, tach, high beam light, and temp. they all merge together and connect to the frame, so you can ground it straight to the frame.
and you dont' have a gray? that's wierd too..look for a gray one on the harness and see what it plugs into after the plug. if not, then you should have 9 wires coming out of your cdi, unless you have a cali bike, the colors should be, gray (2x), white/red, white/black, black, orange, blue/yellow, black/blue, and red/black. i just typed this straight out of my wiring diag. so if there is a color there that isn't supposed to be there, then it's probably the one that has the function of the gray. as i mentioned, there are two grays, one gray goes to the coils, the other goes straight to the tach.
as far as the FJR, i have no idea, but here's yet another link to a wiring diagram:
http://bobblebob.com/bobblebob/FJR-wiring.pdf
as i said the other day, i'll delete it in a few days to avoid going over my monthly limit on the webserver, so download it if you want to keep it.
