I've got a set of racepipes to put onto a hybrid, you knoww the type of thing with springs etc.
Now I'm probably going to a second hybrid with a T'Cat or 4JH engine. I can fit standard downpipes or get some stainless copies ... they don't look good for performance though.
So, is there an aftermarket set available on your side of the pond ???
T'Cat / 600R Downpipes
Evilchicken0
- Level 3.5
FZR400RR 3TJ Bimota SB6
Re: T'Cat / 600R Downpipes
I don't know of any companies that make headers for the YZF600 any longer.
Probably have to go used, if you get in bind and need to order something from the US hit me up. I might not use the D&D T-Cat system I have. If you end up needed to get one from the U.S. let me know.
