661 Crank Seal Issue Solved
As all of you are aware there is trouble with the crank seal if our using yzf cases and fzr rods. I have a guy that makes the special seal. He is out of Austria. If any of you would like a couple of these seals let me know. its a permanent solution to the seal problem. He makes them to order. They are about 10 bucks each and 5 bucks to ship. let me know if anyone wants some. mine should be ready and arriving in about a week. cheers, D
Evilchicken0
- Level 3.5
Re: 661 Crank Seal Issue Solved
We got that one sorted then
FZR400RR 3TJ Bimota SB6
We need a LIKE button.
