33mm keihin flatslides
I have a chance to get a set of 33mm flatslides for my 660 build. they carbs are set up/came off of a 99-02 r6. will it be easy to get them to work on my yzf600r engine? also i was going for 35mm ccause i will be running cam and a few other goodies. these carbs are a great deal and i was just wanting some of your input. fitment, the size, etc. thanks for all your help guys, your the best.
Re: 33mm keihin flatslides
any of you parts masters got any info for me? i reaklly need to know on the quick side. they also have been in storage for about 5 years. and he want 300 bucks for em. so it will need to be rebuilt and fitted to a yzf. is it worth it?
The center to center spacing will be different on two cylinders I believe.
You will have to cut and weld the carb rack rails in at least one (probably two) places each.
thanks for your reply. that was what i was guessing but couldnt get enough info on them and didnt get em in time 350 bucks, dang. also with a 660 mod stage one cams barnett clutch system polished ported head balanced crank and flywheel undercut trans gears. should i go with 33mm or 35mm. i see so many mixed reviews. but eventually i have got to get some regardless. any advise would be awesome. thanks buddy.
