Page 1 of 11
FZR600/YZF600/R6 Build
Posted: Thu Jul 31, 2008 12:25 am
by Genesis
So far, I know I need the whole R6 nose, and an yzf tank, and r6 tail. I am also wanting to go with r6 gauges. So the Bike is stripped down, I'm starting on the Nose first. Couple of questions on the nose though.
Does anyone have a good how-to on this? I know I need a 3/8 spacer, and smaller bolts. I think I am going to have an issue with the brake reservoir hitting the fairing bracket, Should I just go with a r6 brake reservoir? Or is there one that will work better?
I won A complete r6 key set on ebay, so I hope the r6 gas cap will fit the yzf tank. My ignition got screwed up in the accident, and I was thinking about replacing it with a r6 ignition, because I will be doing the yzf tank swap, will a r6 ignition work?
Thanks for the help.
Re: I'm doing a 99 r6 nose and tail, anything I should look for
Posted: Thu Jul 31, 2008 7:39 am
by ragedigital
I don't remember seeing a good How-To on the front. Perfect time for a How-To....
Take lots of pics. We have an excellent GALLERY!
darrin
Posted: Thu Jul 31, 2008 8:31 am
by cad600
Freeze should be able to help with the nose conversion. I know he did a different year/model, but the practical knowledge he's gained from doing his should help. Unfortunatly from what I understand, the R6 gas cap will not work as it is a different size nor will the ignition switch. Might be able to get the switch to work though, but I don't think it will be easy. Could be wrong though. I do know that the YZF series have always had 4 wires coming from the switch and I don't know what the extra one is for. 95FZR600 did a R6 gauge conversion so he should be able to help there.
Posted: Thu Jul 31, 2008 9:33 am
by Fizzinatorr
I did an R1 front conversion on a 1000, so i figure it will be similar
the biggest challenge will be getting the upper on, there's not a whole lot of room with the FZR gauges and stuff, I cut down the FZR Bracket and trimmed where I needed to to get my head light to fit, as centered as possible, and made brackets to attach to the cut down headlight bracket
the sides were pretty easy, i started my planning with some really thin bendable metal with holes, bent to what and where I needed then I fabbed up solid mounts
Posted: Thu Jul 31, 2008 11:17 am
by Genesis
Fizzinatorr wrote:I did an R1 front conversion on a 1000, so i figure it will be similar
Thanks for the info, I took what I thought was the easier route, and went with the r6 fairing stay with thr r6 guages
Posted: Thu Jul 31, 2008 11:21 am
by YAM93
Posted: Thu Jul 31, 2008 12:04 pm
by Fizzinatorr
Genesis wrote:Fizzinatorr wrote:I did an R1 front conversion on a 1000, so i figure it will be similar
GOOD call. that's going to be nice and clean
Posted: Thu Jul 31, 2008 1:12 pm
by Genesis
Bike naked, looks sad
Preliminary fitment of r6 fairing stay
Posted: Thu Jul 31, 2008 1:24 pm
by Genesis
will the r6 clampons fit the FZR forks or will I have to put some sort of bushing around the tubes?
Posted: Thu Jul 31, 2008 1:33 pm
by cad600
R6 Clip-ons will not fit, but Vortex makes aftermarket ones that do. You need 38mm. An R6 brake upgrade might help with the fairing issue as well since it uses a remote resivour.
Posted: Thu Jul 31, 2008 1:41 pm
by Genesis
Posted: Thu Jul 31, 2008 1:54 pm
by Fizzinatorr
i know that someone recently upgraded to R6 controls but i'm not sure if you can use the stock clip-ons, someone should chime in with the answer soon though
Posted: Thu Jul 31, 2008 4:59 pm
by Genesis
Fizzinatorr wrote:i know that someone recently upgraded to R6 controls but i'm not sure if you can use the stock clip-ons, someone should chime in with the answer soon though
I love search, lead me right to it.
r6 control swap How-to
Posted: Thu Jul 31, 2008 8:24 pm
by mrfreeze5
I have a 05 R6 nose and I have encountered a whole slew of problems along the way and still havent finished due to some of them. If youre trying to mate the R6 nose to FZR fairings one big problem is that my R6 nose is horizontal on the bottom edge. The top of the FZR fairings are not horizontal so it leaves a triangular gap. I have fiberglass fairings and can pretty easily add to it to fill it in I just need to get it done. If youre going to use R6 side fairings too it may be easier to adapt them to fit. I havent tried that route.
The nose mount needs several things for mounting to the frame, at least my 05 piece did. First, the mounting tabs on the frame are off center and angled inward a bit. The r6 mount is straight on, not angled, so I had to grind the frame holes to make a surface parallel to the centerline of the frame. On the 05, the distance between the mounting holes is different on the FZR and R6, so the mount wont line up. But there is also about a 3/4" gap from the frame side mount and the nose mount in the position when its centered. I took a solid piece of aluminum and made an adapter.
There is precious little space for guages and I cant use my fancy expensive aftermarket tach now because it wont fit. The R6 guages are very thin, so there just isnt much space if you dont use them. Im running a R1 master cylinder and its close. I am starting to consider the idea of going to those guages, but I still dont think I could get the speedo working, I need to look into this more.
To put the R6 controls on, go with thatkids writeup. The clutch perch will bolt right up to stock clipons, but the clipons do not interchange. Im running a R6 perch so I could run R6 levers.
Posted: Thu Jul 31, 2008 8:37 pm
by mrfreeze5
I think I have have just now decided on changing my guages. I think R1 guages and a speedo healer and Im set and Ill have much more room and will actually funtion a bit better for me.
Im going to use R1 instead of R6 since the R6 is a much higher revving bike and the R1 redline is almost the same as the FZR, the tach matches up better and you dont have to guess at a glance.
