They took about 1/2" off the frame (1/4" off each side). On the swingarm they honed the tube out a little so the bearings are ALOT easier to get in and out and pushed them in as far as they would go. Then they cut the pivot tube flush with the bearings. Originally he was gonna make spacers (like what spyder did on his swingarm) so I could use the fzr bolt but after pushing the bearings in, the stock tube that the bearings ride on was too long. He machined a whole new piece so the outside diameter is the same for the bearings to ride on and the inside diameter is for the fzr pivot bolt so no "reducers" or "spacers" were needed. The craftsmanship is top notch.
