First up is the water pump. I also installed new seals for it.
Pistons and Conrods. New rings, pins, conrod bolts, and rod bearings will be installed.
Cleaned the stator rotor.
Oil pan
Shift linkage
Here is the transmission counter shaft and gears.
The entire transmission was cleaned and inspected.
Clutch basket and parts.
Aftermarket stator cover for a FZR.
Top half of the engine case - before: New crank bearings will be installed.
After
Lower half engine case - before:
After
And I finally got the Ignitech computer today.
I'm going to start putting the lower half together this week.
