SwingArm Bug Bit me
abs929cbrrr
Re: SwingArm Bug Bit me
Post by abs929cbrrr »
just grid them out and tap in the bearing every now and then to see if its snug....that what we did for mine. be prepared to buy new bearings though.
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
abs600fzrr wrote:just grid them out and tap in the bearing every now and then to see if its snug....that what we did for mine. be prepared to buy new bearings though.
+5 on the buy new after using the old for testing your depth as the cage the needles sit in WILL distort and lead to Brinelling the bearing shaft (wear pattern over small area and not allow for proper rotation.)
As to the question of a shoulder not a problem PROVIDING it is not so deep as to go in beyond the bearing surface of the inner core sleeve which has been ground & hardened specially for the bearings to rest on.
If you go outside of that the whole force (weight/torsional forces thro the frame etc) will not be handled by the whole bearing and lead to premature failure.
I know you guys have problem finding competent machinists at reasonable money but these holes should be bored & reamed to size
This is the main load bearing area on your bike adjusting the front to rear axis all the time you are in motion. Nerd
PIMPMYFZR
Post by PIMPMYFZR »
So abs you just grinded the little lip inside nd kept tappin your old ones in till they sat flush ? What did you tap your new ones in with? I seen somwhere online this guy used a long bolt with washers and nuts and put the bearings in the freezer for like 30min said they shrink when frozen dunno where I seen it though
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
PIMPMYFZR
Post by PIMPMYFZR »
Your right George machining is the only way togo . But out here in the states unless your affiliated to somone who works or owns a machining shop , a lot of places won't take the work unless your corporate or have an account with the company
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
abs929cbrrr
used wood and a hammer to tap them back in...no issues.
cad600
Post by cad600 »
Another trick is to use a deep socket that is about the same diameter. Flip the socket over so more surface area is against the bearing (bolt hole up) and tap it in with a hammer. Either way, use a rubber mallet.
Be carefull though. If you start to put it in cockeyed, it will warp the bearing then it's useless.
PIMPMYFZR
Post by PIMPMYFZR »
man i ordered some parts last week friday , some spacers and collars .. those peice of %#$% just send me email tellin me its being shipped out today.
Peoples dont use CHEAPCYCLEPARTS.COM unless u wanna wait forever for the damn parts . :deadhorse:
Was expecting everything in by today so i could start my swap this weekend ..
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
abs929cbrrr
i only use bikebandit.com...comes in 4-5 days
PIMPMYFZR
Post by PIMPMYFZR »
Dude I ordered a set of n bearings from some company in Illinois http://www.powersedge.com . I ordered them Tuesday and they just came and my spacers I ordered last week from cheapcycleparts.com just sent me shippin email today. Wish I had ordered my spacers from this other company .
- now ppl your thoughts as to my wheel color if you don't mind. I can either go all BLACk or paint the inside same color as my bike with a polished lip. I have a matching front wheel for eithe way . Btw my swingarm is black. What color would you do polished lip or all black?
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
sweekster
Post by sweekster »
PIMPMYFZR wrote: - now ppl your thoughts as to my wheel color if you don't mind. I can either go all BLACk or paint the inside same color as my bike with a polished lip. I have a matching front wheel for eithe way . Btw my swingarm is black. What color would you do polished lip or all black?
Black center with polished lips
PIMPMYFZR
Post by PIMPMYFZR »
sweekster wrote: - Black center with polished lips
[/quote]
I like that scheme but then id have to paint my front wheel to match my rear .. damn i dont have anymore patience for this thing.. Wanna install this thing allready !!!! :headbang:
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
PIMPMYFZR
Post by PIMPMYFZR »
So my damn spacers finally came, got everything I need to install this damn thing. 1 problem I can't get my swingarm bearing in for the life of me ! Looks like I'm gonna have to take it somwhere .tapping them in they get stuck half way and won't go in any further
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
mrfreeze5
Level 8.0
Level 8.0
Post by mrfreeze5 »
They are a nice tight press fit. If you have a good solid -heavy- flat surface to use, you can use a small bottle jack with a flat piece of steel to press in evenly. Just brace it underneath something solid and heavy, or solid and bolted down and use the jack as a press. Or any auto shop should be able to press them in with a hydraulic press.
PIMPMYFZR
Post by PIMPMYFZR »
Well after messing with my swingarm bearings , i called the stealership and asked them how much they charge to press in 2 bearing ,, they quoted me $40.
I was not about to give it to them , so i call an old friend who owns a tool and die shop. Low and behold he had a 20 ton hydraulic press , and says sure bring them by .. Never seen those things go in so Ez , he put some loctite on them said these things shouldnt move for the sake of god , So now it's just a matter of finding the time and a friend to help dissassemble the bike with me ,, i work 7 days a week at my resteraunt , and im painting the outside of the building <5000 square feet> so i dont know when ill have time to put this thing in .. ughhh
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
PIMPMYFZR
Post by PIMPMYFZR »
I just got a shinko 180/55 R17 brand new for 70$ has anyone used this brand b4 I've checkd reviews see that most ppl don't prefer them seen others say they last longer then bridgestones and pirellis but for 70 I said what the hell
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
