ABS project 97 FZR600/YZF/ZX6R/WTF
sweekster
Re: ABS project 1990 FZR400/YZF/ZX6R/R1/WTF
Post by sweekster »
Looks nice. Yeah that frame would look better black. So are you gonna keep going with it?
abs929cbrrr
Post by abs929cbrrr »
i think ill keep working on it...i just bought a 91 oem fzr 600 upper and windscreen on ebay last night. i decided not to go R1 upper...its gonan cost me way to much and i already got a ton into this build. i just wont use the stock FZR light :shocker
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
megaloxana
Post by megaloxana »
Glad to hear you're gonna keep goin.
abs929cbrrr
i dont got 3-4K to get a newer bike all at once....but i got 100-200 per month for custo stuff...i almost have nearly every part i need also now so i might as well try to build a fly fzr.
abs929cbrrr
just spoke with the king....wheel spacers are finalized, drawing sent and product will be made out of the strong light shit....7075 aluminum. :bunny :banjoman :shocker
should have product around middle - end of june!!!!!! then i am 1 step closer for the rear end being 100% finished and 100% ready to bolt on.
abs929cbrrr
Re: ABS project 97 FZR600/YZF/ZX6R/WTF
next in line will be the custom 92 upper i have...
figured out how to get small round lights in the 92 upper easy to...just get a street legal dirtbike front numberplate with the lights in it....UFO head light that sells for $60 new on ebay. problem solved, high and low beams, just cut out the middle and plastic bond it to the upper.
should look somthing like this when i am finished. BTW i scored the white ufo number plate for $30 on ebay...it was $59.99 or make offer hehe. the upper has been spray painted black and was not primed at all before they did so. i have 4 hours into sanding it down to the original white and red...prob about 10-12 more hours and it will be ready for plastic bonding. i also just order a plastex kit today so by this time next week i should be able to fix up this upper real nice.
haunter
Post by haunter »
looks good
sweekster
Post by sweekster »
Looks kinda like a 400rr headlight. I was going suggest going with maybe 2 R6 head lights next to each other. But your solution seems MUCH easier.
demon_knight69
Level 4.5
Level 4.5
Post by demon_knight69 »
hey abs, out of curiosity, the 92 (single headlight) fairing uses the same fairing mount bracket right? so if i wanted to use a single headlight fairing on my '96, i wouldn't need the bracket too would i?
1996 FZR 600
K&N Pods
Barnett Clutch
Factory Pro shift kit
Fizzinatorr
Level 6.5
Level 6.5
Post by Fizzinatorr »
yep you would need the bracket to convert the headlight from dual to single
abs929cbrrr
what he said...i dont know much abou tthe 91/92 bike. i just needed the upper fairing
95FZR600
Post by 95FZR600 »
WOW ABS! I just went through and read the whole thread and that is going to be a sweet looking FZR600/YZF/ZX6R/WTF! Keep up the good work and pics because you sure know what you are doing.
Is everything else working out for you? I hope so!
abs929cbrrr
things are comming along. modking finished my wheel spacers so now the rear end is a bolt on. just need to cut down my foot peg area right now to fit the yzf600r swingarm in.
the guy in FL got back to me and my stuff is done so what will be shipped back. i may throw the front and rear end on soon. id like to wait kinda until i paint the frame and everything but i should prob do it now in case i need to mod anything else.
haunter
Post by haunter »
yeah a test fit is a good idea!
abs929cbrrr
02 R6 rim is how mechanicly centered in the yzf600r swingarm. Modking used my drawing i drew up made me some spacers in a very timely mannor. the only mod left for this swap is to weld some on the yzf600r swingarm to attach the R6 rear caliper mount stay. its a pretty sick mod and looks way cooler the the YZf600r stuff...plus you can run a 180 tire.
pics soon of the spacers and everything together.
