Newbie, bought a track fzr4. How can Identify my engine??
Re: Newbie, bought a track fzr4. How can Identify my engine??
Post by thatkid »
First off congratulations on your purchase, looks in fine condition.
ManDogFish wrote:The plastic/rubber thing under the chain on the swingarm seemed to wear out as the bike was ridden in the parking... is this anything to be concerned about?? the bike also starts knocking if you take off in second gear (between 5-10km/hr only)...the knocking is not from the engine, seems like its from the chain.... which doesnt make sense..
A possibility.
In the third photo the chain appears to be slack (or is it my eyes). Also the swing arm has been swapped @ some point, possible causing the front and rear sprockets to be out of alignment? which will cause chain/sprocket grinding (Knocking) Maybe the reason the chain is slack, the PO may have slackened it to quieten the knocking.
The guy's (Freestyle Cad E.T.C.) who have tackled the swing arm swap/sprocket alignment issue can advise you on that.
Just a guess BTW.
