WHAT SWINGARM? 400 Frame / YZF Motor
Re: WHAT SWINGARM? 400 Frame / YZF Motor
Too bad it's 2" longer... I think the YZF is 1/2" longer, but I can cut that off the swinger.
- abs929cbrrr
- 1000+ Posts
YZF600R swingarm is 1/2 longer. i would just deal with it and be done. 1/2" is nothing to worry about. 2-3" longer scares me, reason i stayed with the yzf one.
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
With all that extra welding on the GXSR swingarm, it probably weighs the same as the YZF swingarm anyway... plus, I get to keep the handling characteristics of the FZR400.
- abs929cbrrr
- 1000+ Posts
it will weight more. the yzf is very think steel...the alumium ones are thick and heavy. my R1 swingarm weighted more then my YZF one. its really a waist of time money and weight to do anything else. only one i would of liked to look into more was a 97-00 gsxr 600 one because the srad wheel base is super short and i bet it as long as a fzr/yzf swingarm.
- megaloxana
rage got you the spell check...might want to ask him for grammer check nextabs600fzrr wrote:it will weight more. the yzf is very think steel...the alumium ones are thick and heavy. my R1 swingarm weighted more then my YZF one. its really a waist of time money and weight to do anything else. only one i would of liked to look into more was a 97-00 gsxr 600 one because the srad wheel base is super short and i bet it as long as a fzr/yzf swingarm.
megaloxana wrote:rage got you the spell check...might want to ask him for grammer check nextabs600fzrr wrote:it will weight more. the yzf is very think steel...the alumium ones are thick and heavy. my R1 swingarm weighted more then my YZF one. its really a waist of time money and weight to do anything else. only one i would of liked to look into more was a 97-00 gsxr 600 one because the srad wheel base is super short and i bet it as long as a fzr/yzf swingarm.
- abs929cbrrr
- 1000+ Posts
my cooter hurts
Pics on my site for comparisons :-ragedigital wrote:What is a 3TJ swingarm and what were they found on?
http://www.saltmine.org.uk/fzr/3tj-mod.html
there is also aset of pictures on the site here someplace of all the 600 / 400 swing arm variants
um, TZR250 swingarm baby! is lighter, and not much longer, fits pretty easy and i already worked out the lower shock link setup. you know you want one!
I did that.
