mrfreeze5 wrote:Can you take a picture of the top of your lower triple? Id like a better look at your steering stops. My triple was the prototype and doesnt have stops. i want to see how closethey are in design.
There is a pic of it with the stops up the page some. Still have to extend the tab on the frame for the stops to hit.
I think my solution is an additional spacer below the clamp to raise the clamp high enough for the nut to tighten to it (which is the thickness of the lock nuts, like shred used) and to take this bushing down to the thickness of the clamp, so it's doing it's job, but is out of the way. Then, I think I'd have to raise the forks a couple mm, but nothing drastic.
Freeze, ModKing's lower is a full 1 3/4" thick. My stem is pressed 1" into that (which I think is about the thickness of a stock lower). Do you feel that would be unsafe? Anybody else have any concerns, because I am definitely not a mechanical engineer.
Here it is with the spacer installed....(no bushing in the upper)
And here is how much of the bushing I'd have to do away with.
