I was planning on glassing a adapter piece using the very top of the r6 fairing and mating it up to the fzr fairings.mrfreeze5 wrote:The top of the FZR fairings are not horizontal so it leaves a triangular gap. I have fiberglass fairings and can pretty easily add to it to fill it in I just need to get it done.
How did you measure this?mrfreeze5 wrote:The nose mount needs several things for mounting to the frame, at least my 05 piece did. First, the mounting tabs on the frame are off center and angled inward a bit.
have a picture? I was thinking of doing the same thing. But I can't figure out how to measure it.mrfreeze5 wrote:I took a solid piece of aluminum and made an adapter.
I planned on using the R6 gauges, here is a good write up on this swapmrfreeze5 wrote:There is precious little space for guages and I cant use my fancy expensive aftermarket tach now because it wont fit. The R6 guages are very thin, so there just isnt much space if you dont use them. Im running a R1 master cylinder and its close. I am starting to consider the idea of going to those guages, but I still dont think I could get the speedo working, I need to look into this more.
I striped off the old stuff tonight, I think this should work out well, I'm bidding on some stuff on ebay, But it looks like it will be about $140 including shipping.mrfreeze5 wrote:To put the R6 controls on, go with thatkids writeup. The clutch perch will bolt right up to stock clipons, but the clipons do not interchange. Im running a R6 perch so I could run R6 levers.
It just keeps getting more expensive, as I get farther into this, O well it well look really good, and maybe I will get better gas milage.
BTW freeze thankyou for your writeup it has been very helpful
