FZR600/YZF600/R6 Build
Re: FZR600/YZF600/R6 Build Updated 04-29-2010
More Updates, A buddy helped me finish the tail brackets, well more him than me. it almost looks OEM.
Now its just wiring, exhaust, radiator, and fuel pump bracket
My FZR6 Rebuild
My FZR6 Rebuild
Wow that does look very professional, what year/model R6 tail are you fitting 1998-2002 5eb? if so any chance of measurements/dimensions of those pillion/passenger seat brackets? i've mounted the riders seat, need to fab those pillion seat brackets next.
Thanks
Mal
Thanks
Mal
Freestyle72
- Level 4.0
very clean work man I am lovin it.
Not much to fabbing them. First we set the back bracket against the tube right against the tail light. About the only dimension that is really critical is the angle of the seat, which on my bike is 7 degrees, you can get the angle with the rear seat and fairing seating on the bike. But once you have that back bracket on you will have something to pivot the seat on to get the proper angle. The Latch bracket has the latch slot dead center, and just make it the width of the frame, make your "legs for that bracket a little long, then start grinding off a little at a time checking your angle.mawler wrote:Wow that does look very professional, what year/model R6 tail are you fitting 1998-2002 5eb? if so any chance of measurements/dimensions of those pillion/passenger seat brackets? i've mounted the riders seat, need to fab those pillion seat brackets next.
Thanks
Mal
I will get photos with a tape measurement later.
My FZR6 Rebuild
My FZR6 Rebuild
your work is much cleaner manFreestyle72 wrote:very clean work man I am lovin it.
My FZR6 Rebuild
My FZR6 Rebuild
Thank you Sir.Genesis wrote:Not much to fabbing them. First we set the back bracket against the tube right against the tail light. About the only dimension that is really critical is the angle of the seat, which on my bike is 7 degrees, you can get the angle with the rear seat and fairing seating on the bike. But once you have that back bracket on you will have something to pivot the seat on to get the proper angle. The Latch bracket has the latch slot dead center, and just make it the width of the frame, make your "legs for that bracket a little long, then start grinding off a little at a time checking your angle.mawler wrote:Wow that does look very professional, what year/model R6 tail are you fitting 1998-2002 5eb? if so any chance of measurements/dimensions of those pillion/passenger seat brackets? i've mounted the riders seat, need to fab those pillion seat brackets next.
Thanks
Mal
- shredex
Looks awesome man! very clean!
Don't you love how are frames are not cast?
Sure, lighter is lighter but they cant customize there stuff
I was just making the comment to my buddy, I think he might be getting a FZR to dink around with now.shredex wrote:Looks awesome man! very clean!
Stay tuned for my coolant bottle.
My FZR6 Rebuild
My FZR6 Rebuild
Re: FZR600/YZF600/R6 Build Updated 05-08-2010
I have been doing allot of little fittment things. I found out if you use a heat gun you can reshape the undertail plastic. I also have been working out how to fit the over flow bottle I beliave it is off a banchshee, sp?. It is working fairly well. I have to make the back barcket tomorrow. I also found a rad shop willing to mod a YZF radiator by adding the fzr mounting points on it.
My FZR6 Rebuild
My FZR6 Rebuild
jessespring07
Your pictures are exactly what I have been looking for I am planning to mod my subframe exactly like yours, and you just made it easier!
Pics with the tape measure would probably just spoil me
Thank you so much for the information I hope mine looks as clean as yours!!!!
J Spring
89 FZR 600 (SOLD)
K&N
D&D Pipe
YZF Swingarm
2005 ZX6r
89 FZR 600 (SOLD)
K&N
D&D Pipe
YZF Swingarm
2005 ZX6r
I would love to get you some picturesjessespring07 wrote:Your pictures are exactly what I have been looking for I am planning to mod my subframe exactly like yours, and you just made it easier!
Pics with the tape measure would probably just spoil me.
My FZR6 Rebuild
My FZR6 Rebuild
jessespring07
It would be just fine your doing me a favor! I actually plan on waiting until winter, I already missed out on too many prime days for riding this season.
I plan on welding the metal in and was just curious what is the size of the tube you used for the rear taillight bracket? what is the thickness I should get or is that all my proffesional opinion?
Cant wait to get your pictures!!
J Spring
89 FZR 600 (SOLD)
K&N
D&D Pipe
YZF Swingarm
2005 ZX6r
89 FZR 600 (SOLD)
K&N
D&D Pipe
YZF Swingarm
2005 ZX6r
I have had request for measurements on the welded on tail brackets, I hope this give the info needed.
My FZR6 Rebuild
My FZR6 Rebuild
jessespring07
J Spring
89 FZR 600 (SOLD)
K&N
D&D Pipe
YZF Swingarm
2005 ZX6r
89 FZR 600 (SOLD)
K&N
D&D Pipe
YZF Swingarm
2005 ZX6r
NP Hope your build goes faster than mine. Wow has it been two years and 1 month????jessespring07 wrote:Thanx so much!!!!
My FZR6 Rebuild
My FZR6 Rebuild
