Today I made the most progress on my bike ever...
I almost finished making the mounts for my plastics...right now there is only two things im using zip ties for...
The fzr bottom frame is wider than the r1's bottom of the frame so I had to make a bracked for the front
now this is the only zip tied thing (the other side as well..)
I tucked the tip under the frame because it made it more stable and I dont want it to be EXACTLY like an r1
finally plastic welded the right side bracket on
rear mount...mounts with the frame side screw...
stay mounted up...
I need a 13/16" thick piece of aluminum for the spacing...in the pic Im using a piece of wood I cut...
now on to the left side...
I had to cut around the stator cover for it to fit...theres more to be done to this..
I need r1 mirriors..
everything is pretty dam stable too...I road it today...
then my camera died.....
also today!
I got my new BT014 150/60ZR18 rear tire installed! along with my 45t rear sprocket I got from dru!
I have to say, I love that tire!
I suggest it to anyone!
and its wider too!
its just beautiful!
I wish my batterys for my camera didnt die so I could show you it!
