Yzf Swingarm and R6 99-00 Tail(Finally!!)
Re: Yzf Swingarm and R6 99-00 Tail(Finally!!)
your signature is soo large
Upgrades:
I agree I am actually in the process of finding a good program to change the size.
J Spring
89 FZR 600 (SOLD)
K&N
D&D Pipe
YZF Swingarm
2005 ZX6r
89 FZR 600 (SOLD)
K&N
D&D Pipe
YZF Swingarm
2005 ZX6r
order two sets, and I will buy onejessespring07 wrote:Thanks man!!
I'm thinking even more seriously about keeping the stock color scheme and i know a guy with software to make vinyl so I might have to start measuring!!
My FZR6 Rebuild
My FZR6 Rebuild
I will let you know if i can get a good enough drawing to make her look right!
My buddy races the modified cars and has the equipment to do a lot of vinyl stuff so hopefully i can make her pretty!
J Spring
89 FZR 600 (SOLD)
K&N
D&D Pipe
YZF Swingarm
2005 ZX6r
89 FZR 600 (SOLD)
K&N
D&D Pipe
YZF Swingarm
2005 ZX6r
So i got the swingarm installed all i need to do is get the brake light switch mounted and the chain to clear the left inner footpeg
I dont know if the lifting dog bones will make the chain clear or not did anyone else have this problem?
J Spring
89 FZR 600 (SOLD)
K&N
D&D Pipe
YZF Swingarm
2005 ZX6r
89 FZR 600 (SOLD)
K&N
D&D Pipe
YZF Swingarm
2005 ZX6r
I got the Swingarm mod done with no chain rubbing! I rode it home from my parents which is about 100 miles and it road perfect other than the positive battery cable coming undone for some reason.
To prevent the chain from rubbing the peg mount I used a cresent wrench and some muscle to bend the bracket out slightly which worked. The chain did not hit at all the whole way home! I am also very satisfied with the new tire and the stability of the bike!!!
J Spring
89 FZR 600 (SOLD)
K&N
D&D Pipe
YZF Swingarm
2005 ZX6r
89 FZR 600 (SOLD)
K&N
D&D Pipe
YZF Swingarm
2005 ZX6r
My FZR6 Rebuild
My FZR6 Rebuild
