ABS project 97 FZR600/YZF/ZX6R/WTF
abs929cbrrr
Post by abs929cbrrr »
i am trying to build a hybrid.
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
ragedigital
4000+ Posts
4000+ Posts
Re: ABS project FZR/YZF/ZX6R/R1/WTF
Post by ragedigital »
Are you doing most of the work yourself or is a machine shop going to handle it?
I apologize, but I just don't know your qualifications or abilities. I would love to see a write-up on the R1 swingarm swap.
darrin
billy_awesome
Level 2.0
Level 2.0
Post by billy_awesome »
I wanna see this project get it's wings off the ground ABS!
I know you have been planning this for awhile, but I want to see it done! lol
good luck bro
abs929cbrrr
most of the work i may have somone else do. i know how to run alot of the machines but would need some supervision since i have'nt done much metal working since highschool. i think we are going to start this week. i am calling the guy tonight.
billy_awesome i know im getting there. i was dead set on the yzf600r rear end until i found this r1 stuff by accident looking for fairings on ebay. it turns out it solves alot of problems machining spacers and this and that since my 02 r6 stuff bolts right on since the swingarm is not semitrical on both sides. i figured id try it.
i cant build to much since this is not done yet and my fzr stem in not back from FZRYZFR6 in florida...which i have no way now of contacting him due to the archive going now. i dont know if ill ever get my parts back from him...hes had them going on 6 months now.
ThisEndUp
Level 1.5
Level 1.5
Post by ThisEndUp »
I'm thinking a GSXR750 motor in an FZR400 frame is going to necessitate allot of restructuring. Not to mention engineering. That's quite a jump in power for that frame.How big of an engine has ever been successfully shoe horned into that frame?
Your project title cracked me up..."FZR/YZF/ZX6R/R1/Whatever The f*ck :P
'91 Yamaha FZR600
'09 Aprilia RS 125
'94 Ducati SS/CR 900
'75 Yamaha RD/TD350
'73 Suzuki TR500 Replica
ThisEndUp
Level 1.5
Level 1.5
Post by ThisEndUp »
f*ck,f*ck,f*ck...........hmmmm......censorship :evil: .
'91 Yamaha FZR600
'09 Aprilia RS 125
'75 Yamaha RD/TD350
abs929cbrrr
i am going over to the machine shop thursday night and get the R1 swingarm machined down. its going to fit pretty good.
i am still debating if its cost effectice to go fzr400 frame and a larger motor...i keep learning towards just a 600frame using my frame and motor and part the rest of the bike out. anyway ill have to pics of the R1 stuff and sprocket i am running tonight.
if i could pic up a junk frame i could make a roller and swap my good frame out of my bike. i am buy up tires today i think.
*edit* i just bought the tires. i try to go for sport touring tires, i seem to get about 8-10K miles out of a set...i dont race so i dont need them super soft tires for the street.
heres what i bought. http://www.tiresunlimited.com/images/co ... attack.jpg
ill have them in prob a week and then go get them mounted up and balanced on the rims so ill be ready to have a roller.
abs929cbrrr
Some R1 swingarm dimensions and more issues with it if anyone if brave nuff to copy me.
shock is not in line with the fzr mount, its also shock mounts are different on the lower end.
width of swingarm that gets mounted into the frame is a hair under 10.50" its prob more like 10.45" with the dust caps on. thats all until thursday once i get true dimensions to machine off each side.
burnRuber13
Post by burnRuber13 »
i was wondering if u knew if the honda vfr750 single sided swing arm fits on the fzr
-1994 yamaha FZR600
-shaved frame
-1992 front cowl
-air tech r1 tail
-r6 seat
-1999 yzf 600 tank
-fox rear shock
-vance and hines full exhaust
-stage 3 jet kit
-pod filters
abs929cbrrr
nope...only swingarm thats a bolt on is a fzr400...you gotta machine the VFR one. talk to CAD600 he did it on here.
burnRuber13
iight thanks man
-1994 yamaha FZR600
-shaved frame
-1992 front cowl
-air tech r1 tail
-r6 seat
-1999 yzf 600 tank
-fox rear shock
-stage 3 jet kit
-pod filters
abs929cbrrr
got some dimensions for this swap.
the fzr600 pivot bolt dia is .625". now the I.D. of the 04-06 R1 pivot bolt its .650" you can use the R1 pivot bolt as your sleeve if you cut it down to fit the lenght of the fzr swingarm. its a little larger then i like but if your really anal i would just weld both holes shut and drill them out to .635"-.638"...this is the same dia of the mounting hole in the fzr600 frame.
if you pack the sleeve with greese you should have no problem, remeber its just a sleeve inside a sleeve.
FZR600 swingarm is 19.75" center to center mounting holes with a 1" adjustment slot.
04-06 R1 swingarm is 22.75 center to center mounting holes with a 1" adjustment slot. you should cust 3" out of the swingarm and weld it back together up at the front of the arm.
more info tomorrow once the arm is cut down fit tonight. WOOT
abs929cbrrr
ok the project changed direction for the better not the worse....i an now then proud owner of a 1990 Yamaha FZR400 frame.....
now i can really start the build and not trear mine appart.
thanks haunter!!!!!!
now this bike should be off the hook! Cruisin LOL2 RRBike Agreed WOOT Agreed
cad600
Re: ABS project 1990 FZR400/YZF/ZX6R/R1/WTF
Post by cad600 »
You were talking about engines before and the fact that your keeping the FZR do to cost. With the 400 frame you should be saving weight anyway, so may I suggest 2 options...... Just drop your 600 engine into it or build a 660. It all depends on if you just want more power or reliability. And as you and everyone else has stated, the bore kits don't have the reliability and YZF engines just don't give enough power for what you spend.
Personally, I'm building a 660 for mine this coming winter.
haunter
Post by haunter »
abs600fzrr wrote:ok the project changed direction for the better not the worse....i an now then proud owner of a 1990 Yamaha FZR400 frame.....
RRBike
