megaloxana wrote:I can honestly say that I've extremely excited to see that swinger on your bike. Its gonna look damn good.
Well, Thanks! I cant wait to get started. And I have recruited a friend from class to help me on it to. Im getting closer, the swing arm came today and the wheel and cush by friday. The front 636 sprocket was shipped today.
Woohoo! The front sprocket(JT 14 tooth 05 636) and 02 R6 swingarm have arrived. This weekend Im picking up the chain slider thingy, rear caliper and MC, caliper bracket, Axle bolt and pivot bolt for $50.
Hopefully friday I will have the rim and cush drive. I found a rear 180/55/17 tire locally for $125.
Scored most of my parts today for the swap. I picked up the whole swingarm with both axles, shock/mount, chain slider/chain, MC/caliper, and all small nuts and bolts for $100.00.
Met the guy on craigslist and when I showed up to pick up the parts he met me outside the shop and you would not believe the amount of bikes he had in there....all street bikes. He has 3 1st year Ducati 916's. And about 30 other bikes. Wow. Could not believe the bikes he had. Suppose to meet him and go ride next weekend.
I think he said he's on the archives. That Im checking on and I told him to check us out.
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
Sounds like fun. Both events. Just make sure you get a full face shield for the grinding / cutting. I had a cutoff wheel explode on me twice. Not fun at all.
cad600 wrote:Sounds like fun. Both events. Just make sure you get a full face shield for the grinding / cutting. I had a cutoff wheel explode on me twice. Not fun at all.
I dont think Im going to use my dremmel. I bought some 3 1/2 inch grinding wheels for my angle grinder. But then again, the dremmel is smaller. Will see what works better. Thanks for the reminder on the shield, will grab it from work tomorrow.
Those little dremel wheels are nothing. I had a cutoff wheel from my 4-1/2" angle grinder obliterate into my face on two different occasions. After the first one I went and got the shield. Second time wasn't nearly as scarry.
i will warn you if you dont have a YZF600r motor you front sprocket will not line up...you may end up having to machine your sprocket carrier down .22"
abs600fzrr wrote:i will warn you if you dont have a YZF600r motor you front sprocket will not line up...you may end up having to machine your sprocket carrier down .22"
you hear that mark? you better go get a yzf motor
'92 FZR 600 Airtech R1 kit \*/ 520 conversion \*/ 14F-47R gearing
He's wrong. You can trim-grind more from the left-right side if needed. Pics this weekend. I promise you that everything will line up just like its supposed to.
95FZR600 wrote:He's wrong. You can trim-grind more from the left-right side if needed. Pics this weekend. I promise you that everything will line up just like its supposed to.
Well he did yzf swingarm with R6 wheel ,,custom made spacers <collars> , your using R6 swingarm , do your spacers look like his ? i mean both of you could be wrong or right i guess .. LOL2
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
