dt 50
jake
dt 50
Post by jake »
hi guys i have a dt 50 i have no spark put new points and condenser while changing the condensor one of the coils was cut off is this for the lighting, the condensor and other coil and points are all conected i still have no spark help
Re: dt 50
You cut off a coil while replacing parts, and you now have no spark. My first thought would be to repair the severed wiring ... :headscratch:
Ob rant - Punctuation. Please, use punctuation. You have between 4 and 7 sentences in your post below, and not so much as a comma. If you want people to help, make it easy to read.
jake
Re: dt 50
Post by jake »
some clown cut wires , the condensor and point's wires were soldered and shrink wrapped, the fault lay under the shrink wrap '',.'@ sorted now ,.;' cheers.
