valve clearances and adjustments
tony
100+ Posts
100+ Posts
Post by tony »
where as us older generation were hands on on the two strokes the fourstroke is a lttle more complicated for the younger generation there must be someone on this site who is able and willing to create a thread on valve adjustment clearances and shim replacment any volinteers
apsolus
Level 2.5
Level 2.5
Re: valve clearances and adjustments
Post by apsolus »
Fluff
olie05
Post by olie05 »
apsolus wrote:Fluff
That's pretty lame. If you don't have anything valuable to add to the thread, DON'T POST.
Regarding the valve clearance adjustment, someone did create a write up, it's just on the other site:
http://fzrarchives.com/fzr600/work_benc ... tment.html
The manual is also a great resource for something as in depth as valve clearance adjustments.
tony
100+ Posts
100+ Posts
Post by tony »
i agree olie the link is use full info i myself have never done valve clearances as of a few of the guys around here as we used a great guy to do it for us ,he is no longer with us ,but i will certainly be having a go shortly with a bit of help from the community i am sure i will accomplish ,i will also take photos and a writeup of all procedures and if it goes wrong itll be called ( what not to do) with the shim calculator on here it should be easy
apsolus
Level 2.5
Level 2.5
Post by apsolus »
damn man get a sence of humor this is a forum its not a matter of life or death! dnt wory about it
