A while back I ditched the stock wheel and slapped in a 1992 Suzuki GS500E rear wheel.
I didn't so much like the tire width, though...not enough meat on the ground. Plus, I just wanted a wider rear wheel...and I wanted something that matched the front wheel.
So I built this:
Widened 1.5" (give or take a few mm...). Trued it up and welded the thing solid...and yeah, I had that gap in the middle filled (my guy did a fantastic job...looks like it was always this way).
I had a YZF600R rear wheel so I based most of my build off of that.
I had a HUGE problem with sprockets...the YZF600R came with 47-tooth sprockets...plus or minus a few...and that just doesn't fly with the GS750. I ended up having to go to the Wera forum and someone happened to notice that WR250F sprockets had similar dimensions....SCORE! I had to take a WR250F sprocket and drill the bolt holes out to 10.5mm and it slipped right on!
A gentleman on yzf600r.com (nu600rider) hooked me up with a great deal on the carrier above as well as an axle, caliper, caliper carrier, all the spacers, cush, brembo master, brake line...even the brake pedal. In the end I was able to put this all together:
I should have got a good before pic because I put it all together backwards the first time.
Slipped that bad boy in there...
...then I had to pull it all back apart because I forgot to put the caps on the end of the swingarm pivot...then again because I forgot to put the bearings in there...argg.
In the end this is what I ended up with:
My chain is about 2mm off...I'm having a spacer cut for it today...just have to keep my ride time tame until then.
I did have to put some shims behind the upper strut bolts, but they're long enough to be more than accommodating with my shocks. I also had to bend the push rod on my master cylinder a bit to get it to clear my swingarm, also had to shim my muffler out about 1/4". Only real frustrating thing was a brace for the brake caliper. I ended up drilling and pressing a stud through the swingarm main spar and I tweaked a dogbone from an FZR600 to fit...haven't tried it out. I'm going to go beat on the rear brake here in a bit and see how it holds/stops...I'm probably going to have to do something different, but I guess we'll see.
Not an FZR, but posting by request...
Re: Not an FZR, but posting by request...
Well it's part FZR and YZF so that makes it good and welcomed here. Impressive work on the front an rear end.
the bigger rear wheel makes it look so much better. Nice work man!
Upgrades:
That swingarm looks like a Honda CB swinger...
What CB has a braced swingarm?
Before the bracing....makenzie71 wrote:What CB has a braced swingarm?
Yeah basically everything from the era before alloy swingarms and boxed tubing they were pretty much the same.
