95FZR600 wrote:Did you use that on the engine? Did it work?
Not on the engine but on the inside of the swing arm and sprocket cover. Bike had the original chain on and the PO apparently used grease to lube it. You gotta let the simple green sit for a while but it works.
Duane... Bike: 1994 Yamaha FZR 1000 EXUP
Factory Pro Stage 1 Jetting | K&N Filter | Corbin Seat | ProTek Keyless Gas Cap | GSXR Mirrors My Thread Cage:
Yeah, that area of the bike is nasty oil filled and thick gupe. I need to clean mine as well.
