Still not done.. Have to sand and polish up the peanut cover. Then clean the motor, slap on some high heat primer, followed by a high heat flat black paint. Then sand the inside of the frame and spray on some flat black paint in there as well.. I'm still undecided on the rims yet, but I might still polish the lips. And as for the swing-arm.. I'll do that in the winter if and when I do a swap on it..
So here they are...
In this pic you'll notice a little area not polished.. I've got different plans for that area..
-- Eventually I'll resemble this emoticon D...
