If you remember, I chopped the rear of the tail and added a R6 Undertail. The undertail is easily removed via 4 screws. I did this so the tail light would attach easier and look like it was stock.
Anyhow, the photos will show that I have an electronics mess under there. You'll be able to see where I mounted my Voltage Regulator as well.
I beefed up the underneath of the airtech tail since it was cracking through the top. I simply added welded mess wire and more fiberglass cloth/resin. I can take a photo of that later - if requested. It did add some weight, but it was necessary.
I purchased a bag of rebar caps (orange) from Home Depot. I added them to the back. It was a bit of trail and error. I used threaded rod since I wasn't sure how long I was going to need to make them. It supports the back very well. My 80lb 10 yr old can sit on it without any problems. Course, she would probably slide right off...
For the seat, you will see that I removed the 2 rubber bumpers from the back. I put in more threaded rod and the seat sits over the threaded rods pieces. It makes me push the seat in toward the front of the bike before these will fit onto the rod. It's perfect. People would probably think it is locked down. I realize that the seat will not last forever doing this, so I'm looking for alternatives. Might add some type of metal insert or something later.
Anyway - Enjoy!
