Things that make you go eww!
Post by thatkid »
I'm trying to clean up a pair of Tokico calipers I got with the parts lot. They will be nice and pretty once they are done, but dear lord I'm not even sure how a caliper gets to this point. It was in every single piston housing.
This one looks like the PO drilled between the two housing to allow for more pressure?? It's done on all of them and it doesn't look factory. I would assume it would add more braking force but someone else chime in if they know.
zero9243
Level 8.5
Level 8.5
Re: Things that make you go eww!
Post by zero9243 »
make a PB&J with it!
Upgrades:
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
also, are they getting powdercoated
Upgrades:
Post by thatkid »
zero9243 wrote:also, are they getting powdercoated
They sure are. Once they get soaked in some sort of cleaner for like a week!
scarlett
Post by scarlett »
zero9243 wrote:make a PB&J with it!
dillon you never cease to make me go eww
95FZR600
Post by 95FZR600 »
You should of seen some of the AK-47's I had shipped to me in that cosmo grease. Eeeeewwwww.
Post by thatkid »
95FZR600 wrote:You should of seen some of the AK-47's I had shipped to me in that cosmo grease. Eeeeewwwww.
But that isn't grease! That's supposed to brake fluid....or what brake fluid turns into after a really long and hard life.
shredex
Post by shredex »
ship that grease over to me!
I could use it on my dry a$$ chain...
sweekster
Post by sweekster »
They were probably on a race bike at one time and who ever had them probably used a master that was not matched to them and drilled them to correct for any "wooden" feeling they would give off. But that's just my theory. I'm sure this is something George or one of our other racing members have dealt with and could give a much better explanation. That is pretty gross though.
95FZR600
Post by 95FZR600 »
I know!! But its still eeeewwwwwww.
billy_awesome
Post by billy_awesome »
LOOKS LIKE POO
haunter
Post by haunter »
nice
I pulled some awesome crap like that out of an older YZF600 bluepot setup
shift
Level 1.5
Level 1.5
Post by shift »
looks to me like someone thought the bleeder was a zerk fitting for grease. :rofl:
..........................................................shitf.............................c3po...................next.victim............................................................
to see some of my ride videos, click the link: http://video.google.com/videosearch?q=b ... oogle.com#
may 2009: my 88 fzr 400 sets a speed record at the maxton mile: http://www.youtube.com/watch?v=GlOk-6aUsKc
Post by thatkid »
BMiller wrote:That sure is nasty.........it's no wonder so many people get seized calipers on the old FZR's
Except from duane and I can gather, these are off a 96-01 I think it was ZX6. I'm not having much luck with finding a seal kit though.
