Code Name: Zo-lee
Code Name: Zo-lee
Zolee is my '95 fzr 600. I found her a couple weeks ago. Over the next year; you guys can watch Zolee transform from dirty trailer trash to the girl next door. STAY TUNED
I named my bike Zolee because she has the same effect as my meds- Zoloft.
Re: Code Name: Zo-lee
Here's Zolee
After I had it running the other day.It was running like a bag of poopy though. So I decided to go through the carbs. This is what I got out them, NO WONDER!! I can't believe it ran at all!!!
You seem to be missing your pic links ...
I also drained the coolant. The pan was already dirty. Still though. Looked like poppy
Try Photobucket
Thanks.. I found one.. Hopefully it works
Yeah ... Black and gritty coming out of carbs or rad is rarely a good thing! Given what you've seen so far, I hope you're also changing and flushing your oil and brake fluid?
This be the helmet. TMS dual visor. Has front breather, dual air exhaust on rear, and dual visors; the one inside is tinted and has a switch by the ear to flip it up
Yeah, I ordered a new k&n oil filter, still waiting on that.. Never thought about the brake fluid.. I guess I should give it a look, huh?
These are the turn signals I bought on fleabay... Got four of em.. I'll post pics when they get here and I mount em..
Probably better to replace the lines with SS lines anyhow. Since you seem to plan on keeping her might as well treat her right.
It has a Mr gasket fuel pump on it.. After I put the carbs on I noticed the fuel line gets kinked the way the po has it mounted.. So I need some no kink lines, and a new mounting bracket
Well. I decided not to re-clean my carbs, apparently I did a great job, she runs like a top. Got to taker her out for the FIRST TIME yesterday )))))).
So before I took her out, I dressed 'er up a little bit. Did the high temp paint on headers and half of the slip on.
I painted the windscreen (It was flat black/chipped/scratched) since it looked odd, I masked out some stripes on the rears and matched em.
After everything was done, she doesn't look perfect, but she sure does make me happy ))
